Installing Fan And GFCI Into Existing Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 09:54 PM   #1
Lightbulb
Installing fan and GFCI into existing bathroom
Hi, I'm updating the electrical to my bathroom (mid '50's bungalow). As of now, there is a single switch which controls the vanity light. I want to add an exhaust fan with an independant switch, and a GCFI outlet. I'd like to keep the GFCI last on the circuit so the lights don't go out if it trips. I've included a diagram of what I think may work, going off the one electrical line that is already run to the bathroom (via the attic). If there are any mistakes, or anything I've missed, please let me know.
Thanks!
leftisright is offline   Reply With Quote
Old 08-11-2009, 02:29 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Before I can go on need to know if that exsting conductor is feeded with other rooms or not due there are two legit ways it can be done depending on how it ran.
The other thing that the bathroom circuit must be on 20 amp {#12 AWG conductors }
Merci,Marc
Old 08-11-2009, 06:16 AM   #3
a trick i've learned is that no matter where along a circuit where you have a line wire and a load wire is to rat tail the two wires together with a short jumper going to the gfci plug. this eliminates whatever is on the circuit from the gfci plug since now the line passes on to the load without going through the gfci. just make sure what is required or desired to be gfci protected. also, properly wired, a gfci circuit will not trip for any reasons it is not designed for. i believe you should only wire the light up on your circuit not gfci protected because in case it trips you are not left in the dark. check local codes if warranted. thanks, buddy builder
buddy builder is offline   Reply With Quote
Old 08-11-2009, 07:23 AM   #4
Licensed electrician
Rewards Points: 3,740
Why not just bring the power into the 3g switch box and then run to the fans and lights? No additional junction boxes to make up.
