Installing Dishwasher,Need Advise On Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 01:29 PM   #16
Rewards Points: 3,130
The dishwasher installation instructions should give you the electrical requirements. Other than portables, I've never seen a dishwasher that plugs in - the instructions for the LG unit I just put in didn't even mention that. If it did, I wouldn't do it anyway - hardwiring would be cheaper.
I've never lived where a visible disconnect switch was required, but I had to put a locking device on the breaker in the panel. Kind've silly really, since no other breaker requires one. But at least it was inexpensive.
Old 04-21-2010, 09:15 AM   #17
K.M.G's Avatar
Rewards Points: 119
The Little box on the Dishwasher says this
-Connect to a separate circuit with a fuse or circuit breaker Rated for 15 amp min or 20 amp max 120v ac 60hz only
-Do not use an extension cord
-permanently ground the dishawsher in accordance with the national electrical code and local codes or ordinances
We called an electrician last week
Wants $165
$55 an hour+$25 for materials
Would be using 14/2 wire
Everyone keeps saying a 20 amp fuse with 12/2 wire,so I don't know
My plan is,Run the wire though the joist's and have him hook the dishwasher up and at the panel.
$55 is fine not $165
Should I buy a Roll of 12/2 or 14/2
I don't want to do all this work and the breaker keeps popping if I choose 14/2 even though the electrician says that's what I need.
K.M.G is offline   Reply With Quote
Old 04-21-2010, 09:22 AM   #18
Licensed electrician
Rewards Points: 3,662
Either size wire is fine for that DW. The #14 will cover the 15 minimum circuit size and the #12 would cover the maximum circuit size required.
Old 04-21-2010, 11:12 AM   #19
DW & disposal are allowed on the same circuit
So I would run 12-2 & install a 20a breaker just in case
Old 04-21-2010, 11:29 AM   #20
Electrician
Rewards Points: 910
Run 12/2 if it would help you sleep at night.
The instructions cleary state that you can run it off a 15A circuit so thats what I would do and still sleep good at night.
darren is offline   Reply With Quote
Old 04-21-2010, 02:03 PM   #21
Just call me Andrew
Rewards Points: 1,032
12/2 is barely more money than 14/2. Just go with that. You can still use a 15A breaker if you want with 12/2, but I'd just go 20A.
If you plan to hire an electrician, and he won't use 12/2 like you want, get another one. He is working for you, remember?
Andrew
secutanudu is offline   Reply With Quote
Need advise installing soffit vent scrupul0us Roofing/Siding 11 10-09-2010 07:57 PM
Advise on installing tv display unit bookersbeauty Interior Decorating 2 04-23-2009 04:02 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
