Installing Circuit Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2015, 11:35 AM   #1
Rewards Points: 6
Installing circuit breaker box
What single circuit breaker box can be used for a single pole 15 amp circuit breaker?
Smithdw64 is offline   Reply With Quote
Old 11-16-2015, 11:46 AM   #2
Rewards Points: 5,348
Why are you limiting yourself to a single circuit? Install the box you might need later on and do the job once.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Smithdw64 (11-16-2015)
Old 11-16-2015, 12:06 PM   #3
Oso954's Avatar
Rewards Points: 1,274
Indoors or outdoors ?
Is there some other limitation on size that you are not telling us about?
Some of the small 2slot panels cost more than a 6 slot.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Jump-start (11-16-2015), Smithdw64 (11-16-2015)
Old 11-16-2015, 12:16 PM   #4
Rewards Points: 1,832
If this is a disconnect for a detached building, a simple 15 amp switch will do.
Jump-start is offline   Reply With Quote
The Following 2 Users Say Thank You to Jump-start For This Useful Post:
Jim Port (11-16-2015), Smithdw64 (11-16-2015)
Old 11-16-2015, 01:10 PM   #5
Licensed electrician
Rewards Points: 3,740
You can install a single breaker in a larger panel. What are you trying to do?
Old 11-16-2015, 02:14 PM   #6
Rewards Points: 6
I am running a 14 gauge line off of a 12 gauge line from one storage building to another
Old 11-16-2015, 02:29 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
Stop. Just run #12 and you don't need a breaker. And what you are planning us a code violation.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-16-2015, 03:00 PM   #8
Rewards Points: 1,428
The smallest panel you can get is a 2 space panel.
poiihy is offline   Reply With Quote
The Following User Says Thank You to poiihy For This Useful Post:
Breaker OK / Circuit Down (Non GCFI / Arc Fault Issue) OlDB Electrical 6 07-29-2014 05:49 AM
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-01-2012 11:20 PM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
