Installing 3 Prong Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 09:28 PM   #1
Cool
Installing 3 prong outlet
I have a 2 prong electric outlet that does not appear to be grounded. I would like to install a 3 electrical out if possible.
wwcpacwrc23 is offline   Reply With Quote
Old 10-23-2010, 11:04 PM   #2
Rewards Points: 330
I see that a lot of that here.50's and 60's houses.the ground is there they just didn't have grounded out lets.make sure there is or isn't a ground in the box.by the way are you in canada?
oleguy74 is offline   Reply With Quote
Old 10-24-2010, 08:09 AM   #3
Electrician
Rewards Points: 910
In Canada and the US it is legal to put a GFI on here to get a three prong outlet. This will not give you a equipment ground but offers more protection then just a 2 wire outlet.
darren is offline   Reply With Quote
Old 10-24-2010, 09:15 AM   #4
Rewards Points: 2,800
The GFCI does not offer protection for equipment unless it "thinks" a person may be electrocuted in which case it cuts the power.
An actual ground protects the appliance or equipment, and offers limited protection for you. You must install an actual ground in order to have one. This may be accomplished by running a wire from the green ground terminal of the receptacle along the baseboard and up and around doorways and down to the electrical panel that way if you don't want to fish wires in the walls.
Most spiral sheathed cables notably BX does not make for an adequate ground from one outlet box to the next and down to the panel. The cable would provide a ground if it had a metal strip or wire inside specifically as a ground wire and that was electrically fastened (bonded) to other ground strips or wires at each outlet box.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
3 PRONG vs. 4 PRONG OVEN OUTLET? Casey_Oakland Electrical 17 05-21-2009 08:26 PM
Installing 120VAC Outlet DK75 Electrical 4 11-26-2007 03:51 PM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 05:32 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
