Installation Of Aube TI034-3W - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 04:22 PM   #1
Installation of Aube TI034-3W
I am replacing a GE Smart Digital Timer with an Aube TI034-3W timer. The GE switch is hooked up with 4-wires (the on-off light switch in the same junction box also has 4-wires) while the Aube TI034-3W comes with 3-wires connected and a loose red wire. The Aube instructions are not clear. How do I wire-in the Aube switch?
Tony
aprangus is offline   Reply With Quote
Old 09-05-2010, 04:46 PM   #2
Master Electrician
Rewards Points: 5,084
Is this switch being installed at a 3 way or single pole location?,i.e. is the fixture controlled by more than one switch?
brric is online now   Reply With Quote
Old 09-05-2010, 09:14 PM   #3
brric
The switch only controls the three lights (all on or all off) on our front porch. The second switch in the junction box only controls the light in our entry way.
Tony
Old 09-06-2010, 07:41 AM   #4
Master Electrician
According to the Aube instructions which I found online, wires 2 and C connect to the incoming power at the switchbox. Wire 1 connects to the load wire going to the fixtures. There is also a note stating that the white wire on the switch is NOT a neutral wire. The red wire is for use as a jumper for a 3 way configuration.
Use this link then download the instruction pdf.
http://www.aubetech.com/products/pro...=77&noLangue=2
3-way switch installation - TI070-3W Aube Local Dimwit Electrical 15 05-07-2011 09:33 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
