Induced Current - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 11:13 AM   #1
Induced Current
Hi, I have done a number of small electrical projects around our house over the past few months and have sometimes noticed the following. I have one of those no contact live wire detectors and sometimes it still flashes/beeps even after disconnecting a circuit from the fuse box. (not all circuits do this, just some of them). When I use my multi-meter to measure the voltage in these situations, sometimes I do indeed register a small voltage (maybe 5 volts). Is that normal? Is that due to induced current from other circuits?
mkrawitz is offline   Reply With Quote
Old 04-21-2010, 12:30 PM   #2
Search the word
reactance
on this site.
Old 04-21-2010, 01:19 PM   #3
Rewards Points: 2,800
Yes you are sensing induced current.
When a live conductor is juxtaposed with a dead conductor but not touching, for example in a Romex cable, current leaking between the two can be measured.
The larger the contact area, for example the longer the length over which the conductors are juxtaposed, the larger the current that can leak. Three way switch travelers are a good situation where induced current can be measured.
The closer the conductors are to one another, for example if the insulation is thinner, the larger the current that can leak.
(not really relevant for household wiring) The higher the AC frequency, the larger the current that can leak.
The voltage that the meter shows depends on the "resistance" between the juxtaposed conductors versus the "resistance" of the meter; the larger the latter relative to the former, the larger the voltage reported.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 04-21-2010, 03:40 PM   #4
And if you measure it with a milliammeter instead of a voltmeter you should get about 1/2 milliamp regardless of the meter range selected and the type of meter used.
But in the unlikely event that it's not a phantom voltage then you pop your meter!
New Recepacles in a shallow wall trosenda Electrical 31 11-03-2009 09:07 PM
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 03:11 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
80 leds for led light. can i run to 230v mains donnol1983 Electrical 8 12-27-2007 06:23 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
