Increasing Of Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2013, 02:21 PM   #1
Rewards Points: 99
Increasing of circuit breaker
I have a 15A breaker for this useful outlet in my kitchen. It because I have 3 high wattage appliances attached to this outlet. It blows all the time if I have more than 2 on at the same time.
Can I just go to my breaker box and replace the 15A and drop in a 20A? Or should an electrician inspect my wiring and make sure it's up to guage (or other problems I'm not taking into account?)
edta1 is offline   Reply With Quote
Old 11-27-2013, 02:36 PM   #2
Rewards Points: 17,940
Not a chance.
The wire needs to be 12 gauge for a 20 amp. circuit.
Just change the breaker and the wiring becomes the weak link and melts and burns before the breaker trips.
Main reason why code calls for two GFI protected circuits to the outlet over kitchen counters.
Refrigerator, microwave, stove really should be on there own circuits.
Old 11-27-2013, 02:40 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Even on a 20A circuit 3 high draw appliances will trip. You need more circuits, not bigger circuits. Although 20A is required for kitchen receptacle circuits.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
Jim Port (11-27-2013), plummen (11-27-2013), stickboy1375 (11-27-2013)
Old 11-27-2013, 06:20 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,514
NEVER change a breaker with out first knowing what the cables can safely deliver !
Do you know what size cable it is ?
What is the load requirements ?
I E - How much current does the loads require ?
dmxtothemax is offline   Reply With Quote
Old 11-27-2013, 07:11 PM   #5
Rewards Points: 774
And continually overloading a circuit stresses everything in the circuit, not a good practice.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
Kyle_in_rure (11-27-2013)
Old 11-27-2013, 07:34 PM   #6
Electrical Enthusiast
Rewards Points: 504
You really should consider moving one of those appliances to another circuit. The fact that your are tripping the breaker with three appliances in one receptacle means you might be wearing the receptacle out too. What are these three appliances?
Kyle_in_rure is offline   Reply With Quote
Old 11-27-2013, 10:08 PM   #7
Rewards Points: 917
First, look at the current draw of the 3 appliances. I'm willing to bet the one with the highest current draw is a microwave. I bought a 1200 watt microwave oven recently and right on the instructions it said it needs to have a dedicated circuit.
If you want to make toast and run the microwave at the same time you will have to move one or the other to a different circuit. If you don't you risk wearing out the breaker from tripping it every day.
Or you could hire an electrician to add an additional breaker and pull a new wire to add the capacity you need.
chiraldude is offline   Reply With Quote
Old 11-29-2013, 10:22 AM   #8
Rewards Points: 528
Do check to see the wire size on that circuit as stated earlier in post,and if its 12/2 change out breaker to 20 .Also move some of load to other outlet.and have a gfci on kitchen circuit.
hidden1 is offline   Reply With Quote
Circuit breaker keeps immediately tripping after reset... Ler0y Jenkins Electrical 30 05-22-2013 01:17 PM
does a household circuit breaker have thermal memory? djmieczk Electrical 40 02-10-2013 06:59 PM
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
