Inaccessible Wire In My Attic - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Oso954
  • 2 Post By Oso954
Old 07-09-2018, 11:30 AM   #1
Rewards Points: 4
inaccessible wire in my attic
I have an inaccessible wire in my attic that previously was connect to a closet light.
Can I cap it off or use electrical tape?
There is no possible way to find out where this wire leads to in the attic.
I have blown in insulation up there.
Thank You,
Gary
KJVBIBLE1611 is offline   Reply With Quote
Old 07-09-2018, 12:57 PM   #2
Mike Milam's Avatar
Rewards Points: 212
Re: inaccessible wire in my attic
Believe the best way is to terminate it in a box and leave it visible.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 07-09-2018, 01:10 PM   #3
Rewards Points: 4
There is no box.
Gary
Nice 55 Chevy, ours was red and creme color!!!!
Gary
Old 07-09-2018, 01:17 PM   #4
retired framer
Rewards Points: 13,322
Think you should twist the wires together so it would pop the breaker if someone ever powered it up, I would install a box so it could be found again.
Old 07-09-2018, 01:24 PM   #5
Oso954's Avatar
Rewards Points: 1,660
Add a box up (preferably above the insulation) at a point the wires will reach.
Run the wires into the box. Clamp or staple them so they cannot be pulled out by accident. Cap each insulated wire individually with wire nuts. If your box is metal, terminate the ground wire to the metal box (use a ground screw).
Put a blank cover on the box.
Mike Milam and KJVBIBLE1611 like this.
Oso954 is offline   Reply With Quote
Old 07-09-2018, 02:02 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,710
A live wire must be terminated in an accessible junction box with a cover. If you can find the other end of the cable and disconnect it, then you can do anything you like with it. It is not part of the electrical system anymore.
Old 07-09-2018, 02:02 PM   #7
Oso954's Avatar
Despite a Canadian TV show recommending it, it's not a good practice.
You are creating the biggest fault that is possible at that location.
If the breaker doesn't clear it, you have a big problem unless the main or other up line breaker saves the day.
brric and GrayHair like this.
The Following User Says Thank You to Oso954 For This Useful Post:
brric (07-09-2018)
Installing Ecobee with 2 wire boiler system in basement air handler in attic chemguy0910 HVAC 1 05-23-2017 04:37 AM
wire to light fixture, exposed or in attic Pabsreno Electrical 7 05-12-2017 08:41 PM
running wire with no attic space? drshonts Electrical 9 01-15-2016 11:14 AM
Wire chase from basement to attic hellohello Electrical 5 02-12-2014 09:33 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
