Important Wire Nut And Electrical Tape Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 08:39 AM   #16
Licensed electrician
Rewards Points: 3,654
You could use a standard old work box with the wings that flip out or one of these .
Old 01-06-2010, 08:39 AM   #17
Originally Posted by Wolfies167 View Post
Yeah I could not find the switch combo I was looking for Jerry...this was the only switch I was able to find in Home Depot that would be able to operate both the light and the fan while giving the light fixture dimming capabilities.
It's possibly such a combo switch exists
But it would need to be 2 different switches
IE the switch goes up & turns power on
Then there is a 2nd slide that turns the light on & adjusts the dimmer to the light
Basically something that looks like this, but the 2 switches are independant of each other
Old 01-06-2010, 08:48 AM   #18
Here's a dimmer/timer combo:
http://www.dimndimmer.com/ma-l3t251hw-wh.html
jerryh3 is offline   Reply With Quote
Old 01-06-2010, 08:48 AM   #19
Scuba I was looking for what you described..the picture you have I found those but the button turns the power on and the slide just determines the dim...but I do understand what you described and was unable to locate such a switch.
Wolfies167 is offline   Reply With Quote
Old 01-06-2010, 08:51 AM   #20
The timer would operate the fan I guess...that is possible...
Old 01-06-2010, 08:55 AM   #21
Yep. Did you see the other link I posted of just the switch/dimmer combo?
Old 01-06-2010, 09:04 AM   #22
Yes Jerry, thank you for your help and everyone else..I really appreciate it.
Old 01-06-2010, 12:59 PM   #23
Remodeling Contractor
just replace the box as I posted early with a remodel type 2 gang box. The fan cannot be on with a dimmer. (to avoid it overheating at lower when you use the dimmer) The fan should be on a timer so it remains on at least 15 minutes after you leave the room.
