Illuminated Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 07:01 PM   #1
Rewards Points: 28
Unhappy
illuminated light switch
I had my bathroom remodeled about eight months ago and had new switches installed. The three of them are flickering a little and I never noticed that before. Any advice would be appreciated. I forgot to mention that they are the illuminated switches but that is pretty obvious I guess.
lindapalmbay is offline   Reply With Quote
Old 09-13-2011, 07:02 PM   #2
Rewards Points: 6,652
Change the switches out to non-light switches.
Old 09-13-2011, 08:42 PM   #3
Licensed electrician
Rewards Points: 3,746
Some lighted switches require a neutral which you may not have in the box. Also some lighted switches do not like compact fluorescent bulbs.
Old 09-13-2011, 09:39 PM   #4
Rewards Points: 47
Are you using CFL bulbs? I had that issue with a few of my lighted switches. It turns out that some switches aren't compatible with certain brands of CFL bulbs. Changing the bulb to another brand helped a few, while other switches just refused to work with any CFL bulb. One bulb I used actually flickered while turned off as long as it was on a lighted switch.
Sliding Man is offline   Reply With Quote
Old 09-13-2011, 11:15 PM   #5
dmxtothemax's Avatar
Rewards Points: 7,756
Most illuminated switchs I have seen use neons.
And it is normal for them to flicker.
Nothing to worry about.
Because neons require such a small amount of current to operate,
the small bleed currents that circulate around in
the system can be enough to cause them to flicker.
NORMAL !
dmxtothemax is online now   Reply With Quote
Old 09-14-2011, 06:46 AM   #6
Rewards Points: 28
illuminated light switch flickering
thanks so much for all your input. When I got up this morning they don't seem to be flickering. I'm wondering why but not complaining. I don't have any fluorescent lighting except in the garage and that's the way I like it!!! They are more trouble than they're worth. Some of them you can't dim and I just don't like the light from them. Since I don't think there is a safety issue here I think I'll just wait and see. If it gets worse I'll have it checked for neutral like Jim said. The brand of light switch is Lutron.
Have a great day everyone!!!
Old 09-14-2011, 07:34 AM   #7
Rewards Points: 3,046
Illuminated switches may fail to illuminate when the light being controlled is a CFL or other non-pure resistance type.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Blown Light Switch ogrenjr Electrical 3 03-01-2010 03:42 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
