Ikea Light Fitting Help - Green/yellow Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 05:35 AM   #1
Ikea light fitting help - green/yellow wire
I recently just bought i new light from Ikea. The wires coming out of the ceiling are blu, brown and green/yellow (see attached JPG) and the new light has just brown and blue (See other attached JPG). I'm guessing the blue and brown both get connected to each other but no clue what to do with the green yellow coming out of the ceiling. Any help with this would be greatly appreciated.
Duncan
Ikea light fitting help - green/yellow wire-old_light.jpg   Ikea light fitting help - green/yellow wire-new_light.jpg
duncmorley is offline   Reply With Quote
Old 03-21-2010, 06:58 AM   #2
Sounds like Euro colors. Not that familiar with brown, blue, they are hot/ neutral(I think), green/yel is definitely ground.
Old 03-21-2010, 07:07 AM   #3
Master Electrician
Rewards Points: 5,082
See that embossed circle on the fixture in the first photo? That's the symbol for a ground connection.
brric is offline   Reply With Quote
Old 03-21-2010, 07:17 AM   #4
I am from the UK. What would you suggest I do with the green/yellow wire then?
Old 03-21-2010, 07:21 AM   #5
Master Electrician
The blu, brown, and green/yellow wires appear to me to be part of the fixture. How many and what color are the wires coming out of the ceiling or wall of the premises?
Old 03-21-2010, 07:37 AM   #6
Electrical Contractor
kbsparky's Avatar
The blue conductor is neutral, the brown or red conductors are "hot"
The green/yellow is your ground (earth) conductor. If your new fixture does not have the green in it, then just ignore the one in your ceiling box.
-KB
Old 03-21-2010, 07:53 AM   #7
The ceiling wires are a per photo 1, so blue, brown and green/yellow. I guess I'll just cap off the green/yellow then.
Old 03-21-2010, 10:51 AM   #8
Worked a treat. Thanks for all your help.
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Wiring fluorescenet light fitting josette Electrical 3 03-07-2009 01:00 AM
Recessed light wire size jizzle Electrical 6 12-03-2008 09:56 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 09:04 PM
