I Think I Shorted Out My Outside Electrical Socket??? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2010, 11:13 AM   #1
I think I shorted out my outside electrical socket???
I have an out door fountain plugged into an outside socket. I was cleaning it out and might of gotten some water on the cord. Now the whole socket doesnt work. I've tried resetting the breakers but it still doesn't work. Did I short it out with water?
mrsjennifermay is offline   Reply With Quote
Old 04-16-2010, 11:31 AM   #2
Just call me Andrew
Rewards Points: 1,032
Is this a GFCI outlet (test/reset buttons on it)? If so, it may have tripped and need to be reset. It also could be fed by another GFCI outlet inside (or elsewhere outside). The water could have caused a GFCI earlier in the chain to have tripped.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
mrsjennifermay (04-16-2010)
Old 04-16-2010, 11:32 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
Check the front porch and look for a reset button on the receptacle.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 04-16-2010, 11:37 AM   #4
It's not a GFCI outlet. I tested the extention cord and the fountain- both still work fine so I dont think it had to do with water on the cords. Where do you think I could find a reset button? I'll go look around but did not see one on the outside covered socket.
Old 04-16-2010, 11:41 AM   #5
OMG you're brilliant! I went into my bathroom where there is a plug in on the inside of the house and hit the reset button and now it works!!!! And to think I almost called an electrician!!!
Old 04-16-2010, 01:12 PM   #6
Just call me Andrew
That was easy! Glad you got it working.
Andrew
Old 04-16-2010, 03:20 PM   #7
jbfan's Avatar
Rewards Points: 952
Not brilliant, just made lots of money in the past for the same thing.
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Socket Help! SMBbone Electrical 4 01-26-2010 10:52 AM
Electrical socket question hayzen Electrical 2 01-15-2010 02:16 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
