I Hope This Was OK - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 10:48 AM   #1
Rewards Points: 150
I hope this was OK
I want to run this past you all and see if it was Kosher. I had a single gang box with a single pole switch in it. I tapped power from a light on the same circuit which went to another light controlled by a couple of three way switches. I changed that single gang box to a double gang and put the end of run three way in it, it works fine. Anythig wrong with this?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 09-03-2010, 11:49 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,990
Sounds OK.
Old 09-04-2010, 04:56 PM   #3
Rewards Points: 150
Thanks, I heard somewhere that a circuit should not leave a j box and then return to it, but I guess that doesn't apply to a couple of switches.
Warren Zevon
A resource of Knowledge I hope to plunder. GrayUK New Member Introductions 3 10-06-2009 08:48 AM
I hope I never do that again! handifoot Electrical 6 01-15-2009 03:16 PM
I hope this is the right spot. ffdanf Electrical 8 04-27-2008 10:27 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
