I Changed Light Switch Now No Power In 2 Rooms - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-02-2016, 11:45 AM   #16
Rewards Points: 36
Re: I changed light switch now no power in 2 rooms
Thanks i switched things out, i thought everything was fine now the hallway light doesn't work, smh. This diy has been a disaster because every time i take a deep breath after it looks like i successfully repaired something we find out something else all of a sudden isn't functioning proper.
Tracks of my tears
Installed a new GFCI receptacle in bathroom.
switched receptacle in guests room, new one wasn't working on the bottom, only spare i had was a tamper resistant one. i installed.
I switched old light switch in main bedroom with a new style light switch. After testing i thought i was good to go. Then an hour later my mom ask me why the hall light wouldn't come on. Someone told me to calm down i'm freaking out....These are the reasons why...i do my homework, read, watch tutorials, i know my limitations, i thought changing light switches and receptacles was smooth sailing. As usual i fix something and screw something else up.
i've checked everything i changed, the only thing i haven't changed is....the last time the hall light worked was before i installed GFCI receptacle. i'm thinking when everyone is gone i'll take the GFCI receptacle out and wrap the wires in electrical tape.
One other observation....the light switch i changed in master bedroom had 3 wires and they all looked the same (black coating) i found the hot and assumed the only end that was looped must've been ground. The light switch is working properly. thanks
jigsaww is offline   Reply With Quote
Getting power to a wireless fan switch rickjames8 Electrical 6 09-07-2014 06:46 AM
How do you run power from the Receptacle to Switch to Light? hello18 Electrical 5 12-19-2013 05:23 PM
power source ? for three way switch addition bbrandow99 Electrical 3 02-12-2012 10:08 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
