How'd I Do? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 07:33 PM   #1
How'd I do?
Room with one switch which controlled an outlet, and no ceiling fan. I installed an additional switch for the ceiling fan, ran new wire up through the wall and out of the ceiling, and installed the new fan.
Everything worked...just making sure I did it right!!!??? Whattya think?
BGbasbhat is offline   Reply With Quote
Old 12-16-2010, 07:36 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Was this switched receptale is wired oringally ?
If so the drawaing is correct as long you break the tabs between the brass screws.
Did you have the oringal power comming in at the switch box first ? if so that is proper but if other way around then it will be tricky to deal with it.
Merci,.
Marc
Old 12-16-2010, 08:10 PM   #3
The recepticle was wired originally; but only for the outlet.
I added the new line to the fan by hooking the black line into the new switch along with another black line from the new switch to the power bunch. I also added the fan neutral to the neutral bunch, and the same with the ground.
I labeled the below "New" of what I added to the original setup of just the single outlet switch.
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 03:48 PM
renovating little 50's ranch joni41 New Member Introductions 3 10-25-2009 02:08 PM
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 08:13 PM
Help a hungover guy clear his head. 3 way switch with pic J187 Electrical 10 11-10-2006 08:10 PM
