How To Wire A Fan With Light Kit On Seperate 3 Ways - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jbfan
Old 08-01-2019, 04:06 PM   #1
How to wire a fan with light kit on seperate 3 ways
Hello, I am would like some help on wiring a fan with a light kit. I would like to have the switch for the lights on a separate 3 way and the fan on a separate 3 way. where I can turn on/off the light at two different locations and turn on/off the fan from two different locations. I have draw a diagram to the best of my abilities and not sure if I am on the right path.
dirtbike1288 is offline   Reply With Quote
Old 08-01-2019, 04:15 PM   #2
retired framer
Rewards Points: 4,618
Re: How to wire a fan with light kit on seperate 3 ways
I think that looks right.
Do not use flat bottom gables with scissor trusses.
Old 08-01-2019, 06:49 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,124
Looks good to me.
Old 08-01-2019, 08:04 PM   #4
Acoustics & Electrical
Rewards Points: 134
Thank you for taking the time to develop a detailed, color-coded drawings. Nice work.
I concur with above. Only suggestion would be to consider 3-way dimmers for the lighting, which is a handy feature. I love dimming for the mood/situation.
keep_hope_alive is offline   Reply With Quote
Old 08-01-2019, 09:46 PM   #5
Okay thanks for the tip.
So on the extra white wire and ground do I just wire nut and leave ?
Old 08-01-2019, 10:04 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,262
I always tie them together.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 08-01-2019, 10:07 PM   #7
Rewards Points: 134
To clarify, you aren't saying to tie neutral and ground together. We can't do that. You're saying to maintain continuity of neutral in a separate wire nut from ground.
This installation carries a neutral through to the load. It also bonds all boxes and switches together.
Old 08-01-2019, 10:15 PM   #8
Im saying to put a wire nut on each end of the extra white and the extra ground. So 4 nuts total to keep things covered up and not exposed
Old 08-01-2019, 10:17 PM   #9
Rewards Points: 134
Roger that, thanks for clarifying.
I'd toss a label on them as well, or just write on the wire jacket with a sharpie.
Old 08-01-2019, 10:21 PM   #10
jbfan's Avatar
No, I just tie all the neutrals together and all the grounds. I wouldn't leave unconnected wires in the box in this case.
keep_hope_alive likes this.
