How To Turn A 60 Watt Bulb Into 300 Watt! - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 08:57 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
How to turn a 60 watt bulb into 300 watt!
Just accidentally knock over the lamp while it's turned on.
I accidentally did this while vacuuming and guess the filament must of jumped in a way and reconnected itself to make itself shorter, I have never seen a 60 watt bulb this bright! I'm not sure how long it's going to last though.
Old 01-22-2010, 10:15 AM   #2
Rewards Points: 2,800
You have inadvertently made the bulb into one that is rated for a much lower voltage.
A (n old fashioned incandescent) photoflood lamp (bulb) is simply one rated for a lower voltage (that would give a 750 to 1000 hour lifetime) than the intended (120 volt) operating voltage. Its life is typically something like five hours. In the case of the photoflood, the intent is not only more light out of one lamp but also a more bluish cast (higher color temperature and also higher actual filament temperature).
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 01-23-2010, 06:50 AM   #3
RS: You remind me of a similar situation. I replaced the dome lamp in my car. There was no problem for a day or so until it no longer came on. Checked the bulb, it was OK. The lamp circuit fuse had blown, replaced it but the same happened again. Out of frustration, I checked the current draw of the bulb -- it was a full 5amps. The specified rating of the bulb is 0.5amps. Oddly though, the brightness of the irregular lamp was the same as a normal lamp. I had called Tung-Sol about it, but nothing came of it.
oilseal is offline   Reply With Quote
Old 01-23-2010, 07:58 AM   #4
I find it hard to believe that the bulb that drew 5 amps did not give much more light than the one that drew 1/2 amp.
Putting a higher wattage (or current) bulb where a lower wattage bulb was meant to go will overheat (and also melt plastic parts of) automotive sockets and fixtures just as in household fixtures.
Old 01-23-2010, 01:33 PM   #5
Wire Chewer
Rewards Points: 528
This bulb of mine is still going strong! Well it seems slightly less bright, or I've just gotten used to it. It's never on for long though but it does get turned off/on a lot, so I'm surprised it did not blow. I would not leave it unattended though.
Maybe I should sell it on ebay as a magic light bulb.
Old 01-23-2010, 11:07 PM   #6
Exclamation
I'm surprised the filament didn't give out before you finished writing this post!!!!
spark plug is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 10:46 PM
Tips for Removing GU10 Bulb? djdragan Electrical 5 12-12-2010 09:17 PM
Stupid question about energy efficient light fixtures farmerde Electrical 16 11-16-2008 09:26 PM
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 04:38 PM
