How To Tell How Big My Panel Is??? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 09:40 PM   #31
Rewards Points: 150
Originally Posted by codeone View Post
Its rated for outdoor use and can have up to 40 circuits installed.
Wow, maybe its me not being around electricity very often but 40 circuits in the residential setting is pretty large in it?
Altough they are double which as you just said does not disperse the heat as well.
canyonbc is offline   Reply With Quote
Old 01-11-2010, 09:44 PM   #32
I'll have well over 100 circuits when I am done with the house
Of course 20 of those are for outside
Old 01-11-2010, 09:47 PM   #33
Inspector/Instructor
codeone's Avatar
For an average house of 2000 Sq ft maybe. However some of the houses I inspect are as big as 15,000 Sq ft and have 600 Amp services to 900 Amp services with as many as 10 panels throughout the house.
codeone is offline   Reply With Quote
Old 01-11-2010, 09:48 PM   #34
Rewards Points: 150
Well, never mind then.
Old 01-11-2010, 09:49 PM   #35
Rewards Points: 150
Whew that is huge, that is crazy large.
Are these attached townhouse or single home?
Old 01-11-2010, 09:52 PM   #36
codeone's Avatar
These are single homes. Several homes I have had the privelage to inspect belong to some of the better known Race Car Drivers here in NC in the town of Mooresville (Race City USA).
Old 01-11-2010, 09:54 PM   #37
Rewards Points: 150
Well thank you for everyone let me learn.
In the end changing out the panel will come down to a few key factors.
Safety
Making the system work
If the county were to make me
Money
If I were to change the panel out to another 200 amp service
What panel would you guys recommend? or put into your house?
Old 01-11-2010, 09:57 PM   #38
Rewards Points: 150
Closer to Charoltte, well I just spent the new year in the greater Raleigh area.
Staid near the crabtree valley mall, spent a lot of time in Garner for a wedding on New Years Eve, and out near Wilsonville backing up to Jordan Lake on a Horse Ranch. Also spent an afternoon in Zebulon/Lizzard Lick area.
My girl friends Dad is from Lizard Lick, her mom lived in Raleigh for 10 years in the early 80's
and
Katie's uncle owns a larger horse ranch backing up to Jordan Lake.
Beautiful Country.
Enjoyed the stay alot.
Old 01-11-2010, 10:00 PM   #39
codeone's Avatar
I would probably use either Square D QO or Square D Homeline. Large co will be around for replacement parts for a long time.So many others have gone by the wayside. Cutler-Hammer is also another good brand the CH is equivalent to QO and the BR is Equivalent to Homeline. Either are top National Brands.
Old 01-11-2010, 10:03 PM   #40
codeone's Avatar
and
Beautiful Country.
Next time you come out send us a private message, maybe we could go out for coffie. G-nite for now.
Old 01-11-2010, 10:38 PM   #41
Rewards Points: 150
I will let you know.
I am hoping to head back out in the summer time.
Mike
Old 01-11-2010, 10:42 PM   #42
Rewards Points: 150
So something like this???
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 01-12-2010, 01:27 AM   #43
" Euro " electrician
frenchelectrican's Avatar
Yeah.,
That is one of the common All in one load centre due your location it common used load centre in your area.
I know SqS , ClutterHammer , Seameins and few others do make good all in one load centre.
However if you going to change that all in one load centre normally usealy done with electrician do this due some tricks it have to be deal with it.
And that is typically a half to full day to swap over the load centre depending on what it have to be done.
also I know couple of electricians in this fourm they are famuair with your area so they will fill you in couple more details if need to be.
Merci,Marc
Old 01-12-2010, 04:27 AM   #44
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Why do those main breakers burn? What is different to panels now?
Newer panels, the main breaker is attached by bolts and not just stabbed on the buss like these Crouse-Hinds panels are and I think some Murrays (red main breaker)
Over a period of time this connection becomes loose, causing arcing under a decent load and the rest is history.
With the temperature the way it's been, and heating systems working at their max, I've had 3 of these in the last 2 weeks.
wirenut1110 is offline   Reply With Quote
Old 01-12-2010, 05:37 AM   #45
kbsparky's Avatar
That looks like a 200 Amp. Crouse-Hinds panel. Popular in the early 1990's.
The fine print on the label indicates that the Crouse-Hinds breakers and Westinghouse (now Cutler-Hammer) type BR breakers are suitable for use in this panel.
You should note that your panel has many Homeline breakers installed in it. While they physically fit in there, they are probably not classified for use in this panel.
The GE breaker provided by a link in this thread is also not classified for use in this panel.
This breaker would be suitable for use in this panel, however.
If your main isn't burning up, I would not replace it. If it ain't broke, don't fix it
-KB
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
