How To Tell How Big My Panel Is??? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 04:52 PM   #16
Looks like 200 AMP
You got room for a 2 pole 60 amp breaker to feed the Garage??
SULTINI is offline   Reply With Quote
Old 01-11-2010, 05:45 PM   #17
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
First thing I would do is change out that panel.
I've had countless of those main breakers burn up where they attach to the buss.
wirenut1110 is offline   Reply With Quote
Old 01-11-2010, 06:05 PM   #18
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
I would like to know how it passed inspection with all the twin breakers installed.
HIVOLT is offline   Reply With Quote
Old 01-11-2010, 06:13 PM   #19
Inspector/Instructor
codeone's Avatar
This is a 200 AMP surge rated panel with 160 Amp continous rating.
codeone is offline   Reply With Quote
Old 01-11-2010, 06:16 PM   #20
codeone's Avatar
More than likely its been added to without inspections, I would suspect.
Old 01-11-2010, 06:26 PM   #21
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
It's also a NEMA 3 enclosure and 40 circuits
Old 01-11-2010, 09:24 PM   #22
Rewards Points: 150
Well my pocket book isnt happy but want to do the job correct.
Why do those main breakers burn? What is different to panels now?
The home was built in 1991/1992
canyonbc is offline   Reply With Quote
Old 01-11-2010, 09:25 PM   #23
Rewards Points: 150
Just learning, why are twin breakers bad?
Old 01-11-2010, 09:25 PM   #24
Rewards Points: 150
Can I ask what this means too?
Old 01-11-2010, 09:32 PM   #25
Rewards Points: 150
Good Chance,
My girlfriends parents moved into the home in October of 2000.
The neighborhood was originally 40 homes or so all custom all once acre lots.
A lot of people traded services from framing, electrical work, kitchen cabinets, concrete work, drywall etc.
Not saying all the work was shooty, but some of it was sub parr.
In respects to the inspection I do not know. I can confidently say nothing electrical outside some recessed lights installed in the kitchen and that was replacing another light system.
Old 01-11-2010, 09:33 PM   #26
codeone's Avatar
I spoke to soon in my other post about the inspections, this panel is designed for the twins, its the only way to have 40 circuits in this panel. It is UL listed that way. There is no problem with the Twins.
Some people dont like them because of their half size for heat disapation.
Old 01-11-2010, 09:34 PM   #27
Rewards Points: 150
Originally Posted by SULTINI View Post
Looks like 200 AMP
Is this what you are talking about???
http://www.homedepot.com/Electrical-...atalogId=10053
Thanks,
Mike
Old 01-11-2010, 09:35 PM   #28
codeone's Avatar
Its rated for outdoor use and can have up to 40 circuits installed.
Old 01-11-2010, 09:37 PM   #29
Rewards Points: 150
Ok, can I ask what this means too.
Are you saying the panel is actually designed for a 160 amp panel but will top out at 200 amps
Something like when they say Working Load Limit is 1,000 lbs but strength of the rope is 10,000 lbs????
Is there 200 amp panel, or at least room for a 60 amp? Although sounds like I maybe replacing the whole panel.
Old 01-11-2010, 09:38 PM   #30
Rewards Points: 150
Ok, well that makes a lot of since then.
Is the heat disapation a huge concern???
Are these worst then the old Zinsco boxes?
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
