How To Staple/secure Within Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 12:21 PM   #1
Rewards Points: 91
How to staple/secure within wall?
I've recently run an #12 armored cable from my 200 amp panel to my kitchen for a garbage disposal (20 amp dedicated circuit / 20 amp GFCI receptacle / 20 amp switch / pigtail from GD to receptacle).
I've installed a metal box under the sink and ran the #12 AC to it, then ran a second piece to a switch at the sink. For the switch at the sink, I've used a plastic remodel box that has a plastic clamp that I had to force the armored cable through.
If I added a metal clamp to both wires on the metal box, do I need to secure the cables within 12" of the box?
For the plastic box, do I have to staple within 8" of the plastic box inside the stud? Or, does the plastic clampy thing count? If not, can anyone suggest a trick for stapling/securing within a wall that does not require opening the wall up?
Thanks.
Todd
toddmanqa is offline   Reply With Quote
Old 06-04-2009, 01:19 PM   #2
Licensed Pro
Wires fished behind an existing wall finish do not need to be stapled.
You should use a metal box in the wall since you are using the armored cable, and the receptacle below the sink does not need to be a GFCI (unless local codes require it).
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 01:59 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
