How To Secure Romex From Drywall Into Pvc Box - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Kevin_Essiambre
Old 08-02-2020, 10:48 PM   #1
Rewards Points: 32
how to secure romex from drywall into pvc box
I'm trying to bring romex from inside an interior wall into a 6x6x4 pvc box to begin a conduit that will go outside. I relocated the wires so the are just coming through a hole in the drywall. I thought I could just drill a hole in the back of the box, pull the romex in and continue into my conduit with THHN.
I'm being told I need something at the back of the box to secure the wires (2 individual wires, different circuits).
What do I need, and ideally, if you could give me a link to a 1/2" version at amazon, that would be ideal?
Thank you.
Ricka777 is offline   Reply With Quote
Old 08-02-2020, 10:50 PM   #2
Rewards Points: 214
Re: how to secure romex from drywall into pvc box
https://www.google.com/search?q=romex+connector
JoeSparky is offline   Reply With Quote
The Following User Says Thank You to JoeSparky For This Useful Post:
Ricka777 (08-02-2020)
Old 08-02-2020, 10:52 PM   #3
Electrician
Originally Posted by JoeSparky View Post
to add: I'd recommend the set screw style with a locknut, as I've noticed a lot of times the non-metallic connectors won't snap into the hole in a PVC cox because the plastic is so thick.
JoeSparky likes this.
Do it once, do it to code the first time.
Kevin_Essiambre is offline   Reply With Quote
The Following User Says Thank You to Kevin_Essiambre For This Useful Post:
Old 08-02-2020, 11:26 PM   #4
Rewards Points: 32
I've used these with metal boxes, so I can just use 'em in pvc too? I thought it was going to be something different.
