How To Secure PVC LB To Wall And To Expansion Coupling? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Wiredindallas
Old 03-03-2019, 03:43 PM   #1
Rewards Points: 112
How to Secure PVC LB to Wall and to Expansion Coupling?
Please take a look at the pictures I've attached.
How do I secure the PVC Expansion Coupling to my LB? The expansion coupling has a male adaptor but the LB doesn't have female threads to accept it.
And how do I secure the LB to my exterior garage wall? I've already drilled the appropriate size hole for the LB to fit through.
Thanks.
How to Secure PVC LB to Wall and to Expansion Coupling?-photo-mar-03-2-26-04-pm-copy.jpg   How to Secure PVC LB to Wall and to Expansion Coupling?-photo-mar-03-2-26-28-pm-copy.jpg
spacefrog is offline   Reply With Quote
Old 03-03-2019, 04:11 PM   #2
Rewards Points: 58
Place the expansion coupling low on the wall a foot or so above the ground and strap it on the large portion of the expansion coupling. Use a detail adapter to connect the coupling to the lb with pvc conduit. Do not tightly strap the conduit below the expansion coupling.
spacefrog likes this.
Wiredindallas is online now   Reply With Quote
Old 03-03-2019, 04:15 PM   #3
Rewards Points: 58
Darn spell check! ......use a female adapter .......
Old 03-03-2019, 05:01 PM   #4
Rewards Points: 112
Re: How to Secure PVC LB to Wall and to Expansion Coupling?
Thank you. I think I did as you instructed with the female adapter. I cemented the female adapter to the LB, then screwed in the expansion coupling male side to the LB.
Still confused on what you mean about "strap the conduit below the expansion coupling."
And how do I secure the LB to the wall? Just use some caulk?
How to Secure PVC LB to Wall and to Expansion Coupling?-photo-mar-03-3-55-16-pm-copy.jpg
Old 03-03-2019, 05:26 PM   #5
Property Mgt/Maint
Rewards Points: 6,902
Strap clamps on the pipe is all that is needed to the hold LB in place. Just don't put the clamp on the movable part of the expansion joint. And you may want a little clear silicone on the top side of the LB entry hole to keep water from wicking in.
[political signature removed]
Yodaman is online now   Reply With Quote
Securing a Half Wall cbaur88 Building & Construction 18 02-18-2013 06:43 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
