How To Replace These 3way Switches? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rjniles
Old 11-07-2019, 08:04 AM   #1
Rewards Points: 110
How to replace these 3way switches?
Two 3way switches control an exterior fan/light.
I have seen several conflicting diagrams on Google of how they should be wired so not sure what to do.
How to replace these 3way switches?-20191107_084839_hdr_1573135390502.jpg   How to replace these 3way switches?-20191107_084921_1573135417844.jpg   How to replace these 3way switches?-20191107_084930_1573135439182.jpg
farmerjohn1324 is offline   Reply With Quote
Old 11-07-2019, 08:16 AM   #2
CodeMatters's Avatar
Rewards Points: 7,946
Re: How to replace these 3way switches?
Does the existing switch have two brass screws and a black screw?
If so all you have to do is make sure the wire on the black screw of
the existing switch lands on the black screw of the new switch. The
other 2 wires are called travellers and it doesn't matter if they're
reversed, or not. In other words, they can land on either brass screw.
CodeMatters is online now   Reply With Quote
Old 11-07-2019, 08:31 AM   #3
Rewards Points: 110
Ok. Yes, I determined that and determined which was first in the series by using a multimeter.
Only thing I don't know now is how to set what I want as "on and off" without trial and error.
Old 11-07-2019, 08:41 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,918
Not really any way to set on/off on three ways. If you flip one switch the second one becomes the opposite of what it was.
The Following User Says Thank You to joed For This Useful Post:
Jim Port (11-07-2019)
Old 11-07-2019, 08:45 AM   #5
Swap the travellers.
Old 11-07-2019, 12:41 PM   #6
Master Electrician
Rewards Points: 5,374
Turn one of the 3 ways upside down.
brric is offline   Reply With Quote
Old 11-07-2019, 03:25 PM   #7
Rewards Points: 1,140
There is no "on or off" position to any 3 or 4 way circuit. The circuit is only open or closed. The device in only diverting the current to the open or closed side.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is online now   Reply With Quote
Old 11-07-2019, 05:09 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
Many people like the light to be off when both switches are down or both are up. When 1 is up and other is down the light is on. Silly but that is what some want. If it is not this way switch the travelers on 1 of the switches.
Sent from my Moto E (4) Plus using Tapatalk
FrodoOne likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 11-07-2019, 09:02 PM   #9
Licensed electrician
Rewards Points: 3,836
Even if someone aligned the switches so both up would be on it would be a temporary condition until a switch was changed. Now it would be one up and one down so the up equal on convention is moot.
