How To Repair Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2009, 06:27 AM   #1
artlover13060's Avatar
how to repair wiring
So, I'm working in the ceiling of my basement installing new rafters for a sheetrock ceiling and there is a wire that is in my way and stapled to the floor joist. In my attempt to remove the staple holding the wire, I pushed the screwdriver through the plastic covering on the wire, and blew out three electric plugs. How do I fix this? I don't even know which circuit breaker the line goes to. I can see the path of the wire since the ceiling isn't enclosed. The configuration is: circuit box - break in line - plug - plug - plug. There is a lot of slack in the wire so I have plenty of length to make a repair, but I am not up to messing with the circuit box.
artlover13060 is offline   Reply With Quote
Old 12-14-2009, 06:45 AM   #2
the Musigician
DangerMouse's Avatar
junction box, repair line, replace receps.
unless this area is to be inaccessable, in which case, replace wire.
(power off first, of course)
DM
Old 12-14-2009, 06:46 AM   #3
the Musigician
wait a minute... you shorted it with the screwdriver and it DIDN'T pop a breaker????
DM
Old 12-14-2009, 08:06 AM   #4
DM
I assume that it did. I have tried all the breakers but there is one that won't stick in the on position. I assume that this is the breaker for this line but I'm not sure. How can I determine if this is a live wire? To be on the safe side I plan to throw the master switch for the entire house unless someone has a better idea.
I can install a junction box in an accessible area.
Old 12-14-2009, 08:23 AM   #5
the Musigician
hmmmm.... if it won't stay on, it's likely...
A: the breaker is shot.
B: the wires are still shorted together.
i'd do the repairs, and if the breaker still doesn't work, replace it.
be sure it's the right rating for wire used.
DM
Old 12-14-2009, 10:36 PM   #6
firehawkmph's Avatar
Rewards Points: 2,474
Art,
Next time you go to pull a romex staple, don't use a screwdriver. Use a pair of pliers (ideally lineman's pliers) and pull the staple with the pliers. No chance of damaging the romex then. Grab one leg of the staple at a time and it will come right out.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-15-2009, 12:21 AM   #7
Rewards Points: 1,016
If it's not feasable to replace the entire wire from the breaker panel to the first receptical, then you will need to do a fix in the middle of the wire. Cut and trim back the wires and connect them together color to color with wire nuts. This connection must be contained within a junction box. The junction box must be left accessible - meaning that it can't be inside a wall that gets closed up, for example.
Old 12-18-2009, 09:56 AM   #8
specgrade's Avatar
Rewards Points: 18
Originally Posted by firehawkmph View Post
Art,
Mike Hawkins
A pair of diagonals work very well for removing staples. Just grab a staple leg and pry up. I'll try the linesman pliers pull also, thanks for the tip.
specgrade is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
