How To Pull 110v Out Of 220 In USA Home - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2009, 01:57 PM   #16
You said he did not need to change the breaker
Show me a 20a 240v stove
Old 12-14-2009, 02:03 PM   #17
If you only read half my post or are personal attacks will not be tolerated.
Ok 20A stove
http://www.nextag.com/20-electric-range/shop-html
Take your pick
smeric28 is offline   Reply With Quote
Old 12-14-2009, 02:08 PM   #18
20a = 20 amps....not 20 inch
They are still rated at 40a
Old 12-14-2009, 02:17 PM   #19
Originally Posted by smeric28 View Post
Arguing with you people has annoyed me enough to come up with a different way for him to do this. This way requires no messing with the breaker box at all.
Buy one of these
http://www.stayonline.com/detail.aspx?ID=4751
Its a NEMA 15-30P (for 50a you need 15-50P)
EDIT: you might need a 14-30p or 14-50p if you post a picture i'll tell you which one.
a 3 phase plug...really ?
How does that give him a 120v outlet ?
Old 12-14-2009, 03:05 PM   #20
You want him to put a 50A plug on a gas range and keep the existing receptacle and breaker???
jerryh3 is offline   Reply With Quote
Old 12-14-2009, 03:53 PM   #21
Buy one of these
For 30A use 14/3 SJO cord
For 50A use 12/3 SJO cord
rewire to the back of the stove
Permitted under NEC 2008 240.5 (B)(2) (4) or (6). 30A or 50A respectively
That is assuming the stove is UL listed.(It is)
I don't think he knows what he's talking about but refuses to admit it
240.5 says nothing about connecting a 20a 120v outlet to a 240v 30-50a circuit
It discusses fixture wire...not a 120v 20a outlet
And you can't even pull that one section of code out & ignore the rest of the code
I've yet to see anything that indicates a 20a outlet could be installed on a 30-50a circuit
210.21 (B)(3) lists the required outlet ratings...20a outlet on a 30-50a does not work
Old 12-14-2009, 04:07 PM   #22
422.11 would kill his plan.
Old 12-14-2009, 04:23 PM   #23
OK...back on track
The problem is to get a 110v outlet needed for the gas range. We have 220v for old electrical range. How to convert???
Simple.
In the receptacle box"
1) Remove 50 amp range recep
2) Using short pigtails, install a 120v receptacle on the black, white and bare wires. Cap the red.
At the panel.
1) Remove the 2 pole 50 amp range breaker
2) Hook the black wire to a single pole 20 amp breaker. Cap the red wire.
And obviously.....Turn off and test power before doing any electrical work.
220/221 is offline   Reply With Quote
Old 12-14-2009, 04:54 PM   #24
man you guys are a hoot
Old 12-14-2009, 05:40 PM   #25
It's just for fun. Once in a while a mole pops his head up and you just need to whack'em.
Old 12-17-2009, 02:11 AM   #26
Scared Electrician
Saturday Cowboy's Avatar
Don't forget a Breaker Blank for the panel. Safety First.
R
Saturday Cowboy is offline   Reply With Quote
Old 12-18-2009, 04:28 PM   #27
They have converters for 240-120 , they are used for gas stove conversion, available at the home depot plug directly into the 220 outlet and give you 120. I'm not sure if they have a C\B in them or if they use exisiting C\B in panel.But it's alot less work.You can always change the C\B in the panel to a smaller size as the wire is rated for alot more, I just not sure of the code implications, but maybe someone in the know can chime in.
Cheers
Lab
Model: 548301Store SKU #: 1000106129 No need to install new outlet.Built-in 15 Amp fuse for safety.A 220- to 110-Volt converter.Simply plug gas range 110 Volt plug into the adapter, and then plug adapter into existing electric range 220 Volt outlet.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
lab73 is offline   Reply With Quote
Old 12-18-2009, 05:12 PM   #28
Cheers
Lab
It say sit has a built in 15a fuse
But, just because Orange sells it does not mean it meets code
Interested to know what an Inspector would think of this item
Old 12-18-2009, 05:18 PM   #29
Yeah I caught that just after I re read my post.The package has a CSA approval on it.
Cheers Lab
Old 12-18-2009, 05:41 PM   #30
Also its listed on the Canadian HD site
Does not list a UL listing
I could not find it listed on the US site
Cost to subcontract modest home catbird Building & Construction 25 05-25-2009 07:38 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
Heat escaping from my new home. Bronx Building & Construction 15 02-03-2009 04:59 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
