How To Properly Wire Nut Power Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 10:35 AM   #1
Rewards Points: 154
How to properly wire nut power outlet
Hi,
I am going to take out a power outlet. How would I properly seal the wires? Just use a wirenut on the black and white?
llckll is offline   Reply With Quote
Old 01-09-2010, 10:40 AM   #2
Just call me Andrew
Rewards Points: 1,032
You mean remove it and just cover up the box with a blank cover plate?
How many wires are in this box? If just 2 (black and white) then you can just wire nut each wire individually. If there are more (eg. 2 blacks and 2 whites) you may cut off the rest of the circuit if you remove the outlet without tying the blacks and whites together.
Why remove the outlet anyway? Is it posing a hazard of some sort?
Andrew
secutanudu is offline   Reply With Quote
Old 01-09-2010, 10:44 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a very good question because to me, this sounds like somebody is planning on covering a junction box which is VERBOTEN (forbidden).
tell us it isn't so.
so, why are you removing the receptacle and what do you plan on doing with the junction box the receptacle is in?
Old 01-09-2010, 10:45 AM   #4
Rewards Points: 154
I'll take pics and show you after my lunch.
Old 01-09-2010, 11:06 AM   #5
Rewards Points: 154
It's a bit of a mess underneath the TV. Came like that when I bought the house.
My plan is to get new taller baseboards all around the room. Get a smaller vent cover. In the spring, I'm going to install new hardwood floors.
Old 01-09-2010, 11:13 AM   #6
Licensed electrician
Rewards Points: 3,662
That receptacle may be there to satisfy the spacing requirements. Removal could create a Code issue.
Old 01-09-2010, 11:22 AM   #7
Rewards Points: 154
Let's say I decide to keep the receptacle there. What tool would be best to cut the baseboard so that the receptacle will fit?
But most likely I will take the receptacle and junction box out and cover it with the new baseboard.
Old 01-09-2010, 11:22 AM   #8
Just call me Andrew
And, like nap said, you cannot get a taller baseboard and cover up the box that the wires are in. Any junctions (place where there's 2 wires spliced together) need to be in an accessible box.
How many wires are in the box? 2 or 4? Or more?
Andrew
Old 01-09-2010, 11:26 AM   #9
You are required by code to have an outlet on that wall
If the wire will reach you could move it up above the new baseboard
If there are 2 wires going to the outlet that will make it harder
Old 01-09-2010, 11:27 AM   #10
Rewards Points: 154
Can I just take the junction box out, wire nut the wires, cover it with sheet rock and plaster and run the baseboards?
Old 01-09-2010, 11:28 AM   #11
you know your gonna do this even tho it be wrong
Old 01-09-2010, 11:30 AM   #12
Just call me Andrew
Nope...
Andrew
Old 01-09-2010, 11:30 AM   #13
Rewards Points: 2,800
No. The wire nutted wire ends have to be in a junction box with an exposed cover.
By the way, each wire end must have its own wire nut. Use tape to hold the wire nut on if it won't stay on by itself.
Better, cut a rectangular notch out of the new baseboard so the baseboard will fit over the existing junction box. Use a box extender "ring" so the outlet cover plate, new receptacle and all, will fit smoothly over the hole.
As far as a receptacle being required on that wall, do not remove the receptacle unless a floor lamp with a 6 foot cord and no extension, standing there, or standing 6 feet to the left, or standing 6 feet to the right can still be plugged in (into a different receptacle) without stretching the cord diagonally across the floor.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 01-09-2010, 11:31 AM   #14
Rewards Points: 154
tpolk, you may be right. But I want to do everything legally and by code if possible. I may just cut a rectangle in the new taller baseboard and stick it in that way. At least it will look much neater than what it is now.
Can you help me understand why it is required by law? Does each wall have to have a power receptacle? What about the LAN plug? Can I remove that entirely?
Old 01-09-2010, 11:34 AM   #15
An outlet is required in every wall, LAN/TV/cable are not required
Basically in a wall an outlet is needed every 12', min 1 outlet
I install outlets every 4-6'
Do you have a power outlet behind the TV?
I'm not sure if there is any height requirement on where the outlet needs to be located
A ceiling mounted outlet does not count
No power at outlet furdur Electrical 7 12-19-2009 08:14 PM
Power Outlet & Power Inlet same box? theatretch85 Electrical 4 10-18-2009 03:37 AM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 06:27 PM
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
