How NOT To Wire A Clothes Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2015, 12:53 AM   #1
Rewards Points: 1,832
How NOT to wire a clothes dryer
A warning to DIYs, this is not how you do it.
Jump-start is offline   Reply With Quote
The Following 5 Users Say Thank You to Jump-start For This Useful Post:
danpik (12-11-2015), jbfan (12-11-2015), mm11 (12-11-2015), Msradell (12-11-2015), Speedy Petey (12-11-2015)
Old 12-11-2015, 04:55 AM   #2
Rewards Points: 3,130
Aren't all new dryers 4-wire now??
Old 12-11-2015, 05:18 AM   #3
Only in newer installations. All dryers come without a cord and can be configured for either 3 wire or 4 wire depending on what you have available.
The Following 2 Users Say Thank You to Jump-start For This Useful Post:
Jim Port (12-11-2015), Speedy Petey (12-11-2015)
Old 12-11-2015, 06:52 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
It's not the dryer that makes it a 3-wire or 4-wire. It's the feed/receptacle at the house.
The backs of most dryers haven't changed in probably 40 years.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 12-11-2015, 06:53 AM   #5
This video is freakin' criminal.
SO MUCH wrong it's not funny.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Jim Port (12-11-2015), Jump-start (12-11-2015)
Old 12-11-2015, 07:23 AM   #6
Rewards Points: 125
I seriously hope this isn't from Maytag. I ran out of fingers and toes to count the number of errors even if hardwiring the dryer is legal. The only good thing, this guy won't be back feeding through his dryer outlet.
jimn01 is offline   Reply With Quote
Old 12-11-2015, 09:11 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,372
I went to the youtube site and posted on the video.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
Old 12-11-2015, 09:22 AM   #8
Licensed electrician
Rewards Points: 3,720
They say to use a 3/4 connector and then install a 1/2"?
That screw was tightened on the wire? Are you kidding me. You could watch it moving under the screw head.
Why did we cut the ground off?
Someone at Maytag needs their butt kicked for not checking this crap.
Old 12-11-2015, 09:41 AM   #9
Just followed up up with Maytag customer support chat to make them aware of the issue.
Old 12-11-2015, 09:51 AM   #10
Super Moderator
joed's Avatar
Rewards Points: 30,580
For the DIYs who don't know can you point out all the issue with this video.
I'll start with the obvious ones.
1. NEVER cut off the ground wire.
2. The cable clamp should be clamping the sheathing not the wires after they come out of the sheathing.
Old 12-11-2015, 10:46 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 17,736
Did you see how he was using the wire stripers?
For me, anytime I see someone using those stripers, I know the guy is a hack.
I do have a pair of those. I only use them for cutting 6-32 and 8-32 screws.
ddawg16 is online now   Reply With Quote
Old 12-11-2015, 10:59 AM   #12
Rewards Points: 422
This is what I use exclusively for stripping #12 and #14 wire:
But only because I'm not adept enough at using these:
Pharon is offline   Reply With Quote
The Following User Says Thank You to Pharon For This Useful Post:
jbfan (12-11-2015)
Old 12-11-2015, 01:52 PM   #13
JOATMON
ddawg16's Avatar
That is similar to what I use....
If you are having to rotate the strippers 2-3 times around the wire and then yank on it like your trying to open a Xmas present, I think you might be using the wrong strippers....kinda reminded me of the guy who kept getting zapped
The Following User Says Thank You to ddawg16 For This Useful Post:
Pharon (12-11-2015)
Old 12-11-2015, 04:23 PM   #14
Rewards Points: 422
Yeah, and it's dangerous. You're far more likely to get nicks in the wire doing it that way. And that's what causes heat and fires, probably at least as much as bad wire nut connections.
Old 12-11-2015, 05:04 PM   #15
Rewards Points: 29
It's tightened on the wire because it's a Romex connector... Makes total sense.
Ben25 is offline   Reply With Quote
Gas vs Electric Clothes Dryer?? Master Brian Appliances 32 10-22-2015 10:58 AM
Reason to Convert To 4 Wire Dryer? cbzdel Electrical 9 12-25-2014 09:25 AM
Splicing # 10 dryer wire?? Rvrlicak Electrical 19 03-07-2012 08:55 PM
sub panel using dryer wire ollie2308 Electrical 6 12-23-2010 02:58 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
