How To Mount Outside Receptical On Vinyl Siding - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2010, 02:47 PM   #1
Rewards Points: 726
How to mount outside receptical on vinyl siding
This weekend I am planning on adding an outdoor receptical that will be mounted on the side our the house right around the rim joist area... the house has vinyl siding. What is the best way to mount this box on the house? should the siding be cut back and have a mounting block (I dont know what they are called? those vinyl boxes that you mount stuff like porch lights on) or how would it be done best?
BlueBSH is offline   Reply With Quote
Old 03-30-2010, 02:51 PM   #2
they make boxes for recept and vinyl siding. it looks like what it is, very utilitarian
The older I get the better I was
Old 03-30-2010, 02:58 PM   #3
Electrician
Rudeboy's Avatar
There are many ways that this can be accomplished. The easiest way would be with a "bell box".
Gotta a photo?
Rudeboy is offline   Reply With Quote
Old 03-30-2010, 03:29 PM   #4
Master Electrician
Rewards Points: 5,082
http://www.google.com/url?sa=t&sourc...1id6YuVWBAZAtw
Check out Arlington products.
brric is offline   Reply With Quote
Old 03-30-2010, 04:59 PM   #5
Licensed electrician
Rewards Points: 3,658
Here is a direct link to the Arlington website section for WP mounting products.
http://www.arlcatalog.com/Siding/siding.pdf
Old 03-30-2010, 06:33 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
THIS is by far the easiest way to go.
Old 03-30-2010, 07:15 PM   #7
Electrician
Rudeboy's Avatar
Those are much nicer than a bell box but not easier because you have to cut the siding. With a bell box, one hole and you're done.
But Arlington does make awesome products.
Old 03-30-2010, 09:33 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
those are fine just stay away from the mini recessed blocks you find at homecenters,not that they are bad but the sometimes interfere with the plastic cover that has to go over the new outlets
Tom Struble is offline   Reply With Quote
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 03:45 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 10:13 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
