How Many Slimline (THQP) Double Poles Can I Have? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2019, 03:21 PM   #1
Rewards Points: 26
How many slimline (THQP) double poles can I have?
Hi all,
I have a GE TMC4020CCU Powermark loadcenter (Canadian model) with 40 spaces. The circuit diagram indicates that it can take 80 1/2" breakers (THQP) in any position. But it then says the maximum number of 2 pole THQP breakers is 38. What I don't understand is why this number is not 40? Are there slots in the panel that won't accept 2-pole THQP breakers?
This model is the same as the GE TM4020C80 US model.
A link to the wiring diagram is included in the attachments
Thanks in advance for any help
How many slimline (THQP) double poles can I have?-tmc4020-p1.png   How many slimline (THQP) double poles can I have?-tmc4020-p2.png
lmcancu is offline   Reply With Quote
Old 04-20-2019, 01:02 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
Re: How many slimline (THQP) double poles can I have?
A THQP 2 pole breaker bridges across 2 slots so on each side of the panel you lose the top and bottom 1/2 position.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-20-2019, 06:12 AM   #3
Rewards Points: 588
Why do you need that many circuits?
Let it Snow is offline   Reply With Quote
Old 04-20-2019, 07:37 AM   #4
Rewards Points: 26
Thank you. That makes sense. I was looking to put a THQP double pole in the top right 1" position (slot 2). So basically I can't do that. I will need to move things around as that was my last open slot.
Old 04-20-2019, 07:48 AM   #5
Rewards Points: 26
Follow up question: do the THQP double poles all need to start on an odd 1/2" slot?
Old 04-20-2019, 08:50 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
Yes. They need to bridge 2 slots so they pick up 120 volts for each pole so the output is 240. You can use single pole THQPs in the other half slots.
Old 04-20-2019, 08:53 AM   #7
Rewards Points: 26
Thank you. Finally understand now.
Old 04-20-2019, 09:26 AM   #8
Rewards Points: 58
I am assuming that this is a hypothetical question. If you need 38 - 240 volt circuits, you need more than a 200 amp panel and not use crappy thin breakers. I know this is not the case.
Wiredindallas is offline   Reply With Quote
Old 04-25-2019, 08:50 PM   #9
Rewards Points: 26
It was more to try to understand in which positions I could add the thin THQP 2 pole breaker. My panel is full except for slot 2. I currently have 2 THQP breakers. One 30 amp and one 20 amp. I plan to replace 2 standard 30 amp breakers with 2 slim 30 amp breakers to make room for 2 slots.
Do these THQP breakers have a bad reputation? I have never had any issues with the 2 I have.
Old 04-26-2019, 06:52 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
Install the 2 pole in the bottom of slot 2 and top of slot 4. Fill the remaining half spaces with single poles.
Old 04-26-2019, 08:24 AM   #11
Rewards Points: 588
My experience with 1/2 size breakers is, that over time, their inability to dissipate heat causes problems such as breaker failure. Before you install too many, consider a sub panel.
Old 04-26-2019, 09:15 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
I have some GE THQP (half slot sized) breakers in my main panel that have been there since the house was built 31 years ago. I have rearranged a few with some changes I have made. Never an issue but I will admit I keep them on lightly loaded circuits.
Tags
double pole , panel board , slimline , tandem , thqp
Concrete Lintel vs Double 2x10's sonnaps Concrete, Stone & Masonry 18 08-11-2015 09:46 PM
Single vs. Double Course Vinyl Siding JagGuy Roofing/Siding 2 05-12-2015 06:56 PM
Anyone ever seen two windows not double pane? FixitDragon Windows and Doors 3 04-21-2011 05:58 PM
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 01:52 PM
2 Single Poles to 1 Double GFCI Breaker nuckphoto Electrical 24 11-11-2010 12:40 AM
