How To Get Rid Of Floor Electrical Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 01:56 PM   #1
How to get rid of floor electrical outlet?
Hi I am getting ready to put in hardwood flooring and would like to get rid of a floor outlet first.Its on the first level over top a finished basement.Can I just cap it off and put the flooring over top?
petrismith is offline   Reply With Quote
Old 07-01-2010, 02:22 PM   #2
Do work
Rewards Points: 81
I'm no expert, but I dont think you can cover over an outlet. Remove the box and pull the wire back. That would be the right thing to do.
liquidvw is offline   Reply With Quote
Old 07-01-2010, 03:02 PM   #3
Licensed electrician
Rewards Points: 3,654
If it is needed to meet the required receptacle spacing it would need to be maintained.
Old 07-01-2010, 03:04 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
You could cut it out completely by removing the wire from it's feeder, if you have access, but I don't think you can just cover it if it's live. It would count as hiding a junction box.
Old 07-01-2010, 05:24 PM   #5
You can't remove the outlet & leave the live wires in the box, capped or not
Any live wires must be accessible
You would need to disconnect the wires that feed this outlet if you are covering it
And, as stated - if it is needed to meet code for distance between outlets it must remain
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
