How To Find Out What Breaker I Need - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 05:01 PM   #16
Properly informed about what will work best, the OP can or should get someone else to do it.
Old 04-28-2010, 05:02 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
Originally Posted by fuseone View Post
So I take it that would be for 120. And yes I understand I'm a new and I accept the risks involved.
Just make sure the main power is off before you try to remove or install the breaker.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 04-28-2010, 05:04 PM   #18
May be a noob but I do have common sense lol.
fuseone is offline   Reply With Quote
Old 04-28-2010, 05:12 PM   #19
Wear level 2 arc flash gear. It's not that much. And no synthetics; when bad things happen they melt onto your skin.
Old 04-28-2010, 05:20 PM   #20
What bad thing will happen if I shut down the main power?
Old 04-28-2010, 05:31 PM   #21
Might need to reset some clocks
Depending upon your setup the main hot feeds are usually always live
Bad thing that could happen is you have a defective main breaker & it won't go back on
Doesn't happen that often, but have heard of it happening
Old 04-28-2010, 07:56 PM   #22
Well since few said it was out of my leage I figured i would called up someone I know that does this kind of work to do it.
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
Extending wire from meter box proge Electrical 11 08-13-2009 06:30 PM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 04:13 AM
cannot find the right breaker pat72 Electrical 11 08-08-2008 12:26 AM
Holy smoking commander breaker drogosandybanks Electrical 13 01-10-2007 02:34 PM
