How To Find Out What Breaker I Need - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 10:36 AM   #1
How to find out what breaker I need
Ok one of the circuit breakers are bad in my house. How do I find out what kind of circuit breaker I will need and how many amps and how much voltage.
fuseone is offline   Reply With Quote
Old 04-28-2010, 10:41 AM   #2
Licensed electrician
Rewards Points: 3,662
The panel brand will tell you what brand of breaker you need. The amp rating of the breaker is typically on the hadle of the breaker. A double wide breaker is for 240 volts, a single wide is for 120 volts, unless it has 2 handles on it. Then it is a tandem breaker which is actually 2 breakers in one case.
Old 04-28-2010, 11:11 AM   #3
So I have to buy the same brand name circuit breaker as the circuit box? And the circuit breaker onle switch one it. I can look later for the name so that way maybe someone can tell me where I can find them at.
Old 04-28-2010, 11:23 AM   #4
For most panels, Yes you need to buy the same Mfg
Some are interchangeable....but you can't just go out & buy any 15a or 20a breaker & install it
If you can tell us the Mfg someone will know your options
If you can post a pic too that might help
Old 04-28-2010, 02:27 PM   #5
If there are compressors on this breaker you might want a CB with a trip curve that can handle this type of load without nuisance trips.
Old 04-28-2010, 03:19 PM   #6
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Take a picture of the panel and post it that will help us understand what you need.
Big N8 is offline   Reply With Quote
Old 04-28-2010, 04:38 PM   #7
http://img87.imageshack.us/i/68436524.jpg/ http://img682.imageshack.us/i/image9k.jpg/ http://img87.imageshack.us/i/68436524.jpg/ http://img689.imageshack.us/i/imagex.../image1jv.jpg/ http://img199.imageshack.us/i/image3diq.jpg/ I took a few pictures wasnt sure which I would need sorry took The picutres on a Iphone so there was no flash had to use a flash light.
Old 04-28-2010, 04:45 PM   #8
Master Electrician
Rewards Points: 5,082
Square D QO breakers.
brric is online now   Reply With Quote
Old 04-28-2010, 04:47 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 972
A square d, qo breaker should fit.
How do you know you have a bad breaker and not a short circuit?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 04-28-2010, 04:49 PM   #10
Moved the stuff to another breaker and it all works cuz nothing was working with the one breaker. How do I fond out how many volts and amps the breaker needs to be and where can I buy them at?
Old 04-28-2010, 04:52 PM   #11
jbfan's Avatar
Rewards Points: 972
The amps will be listed on the breaker, either a 15 or 20 amp.
Is this a single pole or 2 pole breaker.
What does this feed?
Hd, lowes, or a hardware store.
Old 04-28-2010, 04:53 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 704
I know this is a DIY site but a person asking these type of questions should not be changing circuit breakers.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-28-2010, 04:54 PM   #13
What do u mean by single pole or two pole?
Normally I deal with cars not houses
Old 04-28-2010, 04:56 PM   #14
jbfan's Avatar
Rewards Points: 972
I agree now!
Old 04-28-2010, 04:58 PM   #15
looked and it's a single
So I take it that would be for 120. And yes I understand I'm a new and I accept the risks involved.
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
Extending wire from meter box proge Electrical 11 08-13-2009 06:30 PM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 04:13 AM
cannot find the right breaker pat72 Electrical 11 08-08-2008 12:26 AM
Holy smoking commander breaker drogosandybanks Electrical 13 01-10-2007 02:34 PM
