How Do I Wire A 110 V Light From 220 For Hot Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 2 Post By rjniles
  • 3 Post By Speedy Petey
  • 2 Post By rjniles
  • 1 Post By dmxtothemax
Old 04-15-2017, 06:07 AM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
How do I wire a 110 v Light from 220 for Hot Water Heater
I have a 10-2 wire running from my 200 amp service panel to my hot water location in my shed. I would like to wire an "on indicator light" inline so when the breaker is on the light is on as i dont need the hot water heater on all the time and want to turn the breaker off when i am not in there for a couple weeks.
i am assuming that i can use one of the hot lines, but am wondering if i can grab a neutral from a nearby outlet or light junction box?
HandyDave is offline   Reply With Quote
Old 04-15-2017, 07:13 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 196
Re: How do I wire a 110 v Light from 220 for Hot Water Heater
You can not use a neutral from another circuit.
Use a 240 volt bulb. Or use a contactor relay with the coil operated by the WH power and a bulb operated through the contacts from the other circuit.
Sent from my RCT6203W46 using Tapatalk
Speedy Petey and circuitman like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-15-2017, 07:33 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I'd use a 240V indicator light as opposed to a light bulb.
I am wondering why you even need a light. Just look at the breaker.
Old 04-15-2017, 07:55 AM   #4
Demolition Mode
Rewards Points: 129
I need a "reminder" that it is on before i leave the building.. or the wife is NOT happy when the electric bill comes in
Perhaps a note on the door reminding me will suffice
Old 04-15-2017, 09:32 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 196
When I owned a mountain cabin, it was a established routine to turn off the breakers for the WH and the well pump on the way out the door.
joecaption and circuitman like this.
Old 04-15-2017, 09:34 AM   #6
Rewards Points: 2,662
When you say this, I assume that you mean a "Neon Indicator".
If so, can you point HandyDave towards a 220/240 V "indicator light" of the type which you envisage which is suitable for mounting in a North American standard wall plate or another appropriate approved fitting.
I ask this because I have found on line only 120V devices suitable for such mounting in that area (e. g. https://www.amazon.com/22mm-Indicato.../dp/B00ISAQAQW)
Yes, it is a LED. Are there any similarly dimensioned 220/240 V LEDs or Neons available?
FrodoOne is offline   Reply With Quote
The Following User Says Thank You to FrodoOne For This Useful Post:
HandyDave (04-15-2017)
Old 04-15-2017, 11:36 AM   #7
Oso954's Avatar
Rewards Points: 674
how is this one as an example ?
https://www.amazon.com/Power-Indicat.../dp/B00DUW2NSC
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
FrodoOne (04-15-2017), HandyDave (04-15-2017)
Old 04-15-2017, 06:20 PM   #8
Rewards Points: 18,232
I agree that's summer home 101, on the way out hit the breakers, no light needed.
Old 04-15-2017, 07:38 PM   #9
Demolition Mode
Rewards Points: 129
Originally Posted by Oso954 View Post
This is perfect!!! two 110 wires into it! Perfect!! THANKS everyone
Old 04-15-2017, 09:03 PM   #10
dmxtothemax's Avatar
Rewards Points: 7,670
Originally Posted by HandyDave View Post
I need a "reminder" that it is on before i leave the building, or the wife is NOT happy when the electric bill comes in
Ditto - the easiest way would be to use a 240v light.
That way your not messing around with other wiring.
Or if you like you can use 2 x 120v lights in series.
put one inside the shed near the heater.
the other can be put in a more obvious position
such as outside under the eaves.
circuitman likes this.
dmxtothemax is offline   Reply With Quote
Water heater pilot light is lit, but burner won't light jawest Plumbing 1 01-18-2013 10:13 AM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 02:53 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Wire gauge for water heater and rewiring poesprogeny Electrical 15 11-18-2011 07:22 AM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 05:42 PM
