Thread Tools | Display Modes |
#1 |
Rewards Points: 8
![]() How do i remove this can?
Hey guys. New user and I am looking to replace this can with a hanging light. I can't seem to figure out how to get this out of the ceiling. The only tabs I see are riveted into the housing and I don't want to ruin the ceiling or break anything.
Thank you! Alan |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 8
![]() Re: How do i remove this can?
miss post
Advertisement |
#3 |
Rewards Points: 8
![]() Re: How do i remove this can?![]() |
Advertisement |
#4 |
Licensed electrician
Rewards Points: 3,678
Is that a drop ceiling?
jbfan likes this.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#5 |
Rewards Points: 8
No it is a finished kitchen ceiling
#6 |
Rewards Points: 18,118
Any access from above to remove it?
What size is it?
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#7 |
Rewards Points: 7,598
some cans use spring loaded fingers,
for these you just have to pull it out, they don't come out easy, the springs are quite strong. They have to be. Watch your fingers when it comes out the fingers snap back with some force, If your fingers are in the way you will regret it ! |
#8 |
Electrical Contractor
![]() Join Date: Jun 2004
Rewards Points: 6,106
Yes I am a pirate, two hundred years too late The cannons don't thunder, there's nothing to plunder I'm an over-forty victim of fate. |
#9 |
Zooming in on the photo, it looks like it's a Juno model "ic1" recessed lighting. If so, there are brackets above the tile/sheetrock that is holding the can in place. Google "juno ic1" or look at the photos from this lowes.com site:
http://www.lowes.com/pd/Juno-New-Con...4-5-in/1111989 |
#10 | |
Licensed Electrical Cont.
Rewards Points: 2,006
![]() Re: How do i remove this can?Quote:
Sometimes the can can be slid down, others have screws that hold it in place. The kind that is slid up in place can be usually be removed by putting your fingers up into the can and holding it on opposite sides. Meaning cross your wrists and have your right hand on the left and your left hand on the right. This will give you the pressure and leverage you need to twist the can down.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#11 |
A "Handy Husband"
Rewards Points: 94
Rather than remove it you might want to use a "recessed light conversion kit".
https://www.amazon.com/s/?ie=UTF8&ke...l_1ajq446ivc_e
My electrical answers are based on 2014 NEC, you may have local amendments. Location: Coastal South Carolina |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
can i remove | Amitabh | Building & Construction | 0 | 06-08-2016 07:42 PM |
How to remove shower pan? | timnancyk | Plumbing | 17 | 01-11-2016 04:06 PM |
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT | Kirchf | Painting | 0 | 05-27-2015 12:19 PM |
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! | flipjarg | Flooring | 3 | 02-15-2010 10:09 PM |
How can I remove my gutter / apron with out pulling the first row of shingels | wamyers92 | Roofing/Siding | 3 | 07-02-2008 03:10 AM |
