How Do I Properly Ground This Service Panel (pics) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2019, 06:04 PM   #1
Rewards Points: 140
How do I properly ground this service panel (pics)
An inspector said, in passing, that I needed the 8ft ground rod. I will do that. I just have no idea how or where to connect it to the service panel.
Also, I ran a copper line over to the box but didnt contact it with the actual neutral bar. I just clamped it in with a knockout. That was before I knew anything.
Anyways, when I touch one of the current lines and the box itself, my tester indicates 120v, or, from what I hear, that that means the box is actually grounded.
I also must have completely missed installing the bonding jumper. I am assuming the new homeline box came with it
actual box > https://www.schneider-electric.us/en...C-combo%2C-vp/
I basically have two main questions
1- Where do I attach the copper wire Ill run from the ground rod I'll install outside while adhering to NEC specs/code, and
2- Was I accurate with copper grounding wire on the right, and if not, should that continue on to somewhere on the neutral/ground bar
friesbruh is offline   Reply With Quote
Old 04-24-2019, 06:50 PM   #2
hkstroud's Avatar
Rewards Points: 5,548
Re: How do I properly ground this service panel (pics)
The ground/neutral buss bar usually has a larger opening for the ground rod conductor.
Usually at the top or the bottom. I believe yours is at the top.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 04-24-2019, 07:05 PM   #3
Rewards Points: 2,570
The wire from the ground rod connects to the neutral/grounding bar. So does any other grounds.
LawnGuyLandSparky is online now   Reply With Quote
Old 04-24-2019, 07:54 PM   #4
Rewards Points: 322
Every inspector I know will fail having more than an inch of the outside sheath of the romex inside the panel. It's flammable and a fire hazard.
Let it Snow is offline   Reply With Quote
Old 04-24-2019, 08:04 PM   #5
Rewards Points: 140
I think I know where its at. You can barely see where it may be in the pictures. Off center to the right at the very top. That MIGHT be it.
Awesome.
Damn. might go ahead and remove all but 1inch then
Old 04-24-2019, 08:06 PM   #6
Rewards Points: 322
There's a lug next to the neutral that will work. Is that wire going to the main breaker 2/0 aluminum ?
Old 04-24-2019, 08:09 PM   #7
Rewards Points: 140
It is aluminum. The size, I do not know. I looked on the line and no numbers are visible.
Old 04-24-2019, 08:33 PM   #8
Licensed electrician
Rewards Points: 3,592
The bond screw location is shown on the panel label.
Old 04-24-2019, 08:47 PM   #9
Rewards Points: 58
Is there a main breaker/disconnect ahead of this panel? The ground wire (grounding electrode conductor) goes to the 1st means of disconnect. If this panel is directly feed from the meter, you need a main breaker on this panel.
Wiredindallas is offline   Reply With Quote
Old 04-24-2019, 08:52 PM   #10
The panel has a main.
Old 04-25-2019, 09:55 AM   #11
Rewards Points: 58
My fault, I now see the main breaker (barely). The NEC and the city where I am require 2 ground rods several feet apart either 6 or 8 feet. Also, you need to ground the water piping if it is metal.
help me with sorting out panel sub panel install the13bats Electrical 33 08-03-2018 11:03 AM
Wire Sizes and Ground Question for Running 100A Subpanel from Main Panel Norcaltrd Electrical 14 03-22-2015 09:39 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
