How Do I Install A Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2019, 09:40 PM   #1
Rewards Points: 3,209
How do I install a switch?
My laundry room light has three prongs. It plugs into this 2 prong switch. The ground prong hangs in the air. I want to convert that to a 3 prong outlet and add a wall switch for the light by the door. How would I wire that?
mathmonger is offline   Reply With Quote
Old 11-08-2019, 11:18 PM   #2
Re: How do I install a switch?
I think I figured it out. Just run 2 hots to the switch and cap off the neutral in the switch box. I can do that. I can probably ground it to the box since it has that BX cable.
I'm thinking plastic or metal conduit with THHN wire going to the switch would be better than the BX.
Old 11-09-2019, 06:53 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,622
If your plans are to continue the ground, then use AC and a metal box with proper fittings. You will tie the neutrals together, not cap one off. You will make a switch loop and mark the white in the AC with black tape once it emerges on both ends of the set up.
It's hard to tell where this is located in the room and which is up or down.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-09-2019, 12:06 PM   #4
Rewards Points: 680
I'd say the cords plugged into the receptacle fall down.
LawnGuyLandSparky is offline   Reply With Quote
Old 11-09-2019, 12:13 PM   #5
retired framer
Rewards Points: 15,550
I would start by checking if there is a ground there.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 11-09-2019, 01:44 PM   #6
Yeah, I've got 120 volts if I touch the outside of the metal box. So I guess that means I have a good ground?
The outlet is by the ceiling, so I want to run it across the ceiling, squeeze it under a big duct, and run it down the wall by the door so I can turn the light on when I walk in. I read somewhere that new boxes should have a neutral. So I thought I had to put a neutral in with the switch even if I don't use it for anything?
Armored cable would be easier I guess. But I thought some conduit would look a little cleaner. I don't know. Which is cheaper?
