House Fan Not Working On 'Low' - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 02:09 PM   #1
House fan not working on 'Low'
On my second floor with a High / Low switch and a timer hooked up to it. The fan works fine on high and the timer works - but if I try to put it on low it stalls out. I can hear it try to work - it sounds kind of like trying to get a car to turn over. It starts up, spins for a second and stops and repeats that cycle until I turn it off or set it to high. The fan was installed when I bought the house so I have no idea how old it is or its brand / model.
Does anyone know what might be causing the problems on low, is it still OK to run it on high, even with the issues on low and is this something that can be fixed easily or does it require special services - electrician or otherwise?
cellophane is offline   Reply With Quote
Old 03-26-2010, 05:55 PM   #2
Master Electrician
sounds like on the low setting it's not getting enough voltage to turn it over. Keep in mind that a motor need far more juice to start up than it does once it's running. It sounds like it should be just fine on the high setting but as always with electrical you can never be too carefull.
andrew79 is offline   Reply With Quote
Old 03-26-2010, 06:41 PM   #3
Master Electrician
Rewards Points: 5,084
Is there a pull chain switch on the unit? If so, make sure it is on high speed or the motor will stall.
brric is offline   Reply With Quote
Old 03-26-2010, 07:07 PM   #4
the Musigician
DangerMouse's Avatar
If it's a very old, (but powerful) one like mine, it needs oil in that little tube with the cap with the spring holding it shut.....
DM
Old 03-26-2010, 08:29 PM   #5
Rewards Points: 2,800
The fan and the high-low switch are incompatible, or you did not wire it up correctly.
Multispeed (as opposed to variable speed) motors have several leads which are connected to hot and neutral in different combinations to get the different speeds.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-26-2010, 08:46 PM   #6
the Musigician
I don't think he wired it, Allan. I'm sure it worked fine at one point in time.
DM
Old 03-27-2010, 07:00 AM   #7
Rewards Points: 196
needs a part
I had the same problem with the heater A/C fan in my car. Worked fine on high but no low or medium. Found the high is wired directly to the fan motor but the low and medium go through a resistor block which was burned out. Easy fix as new resistor block just plugged in.
If there is a wiring diagram, look at what is between the low speed contact on the switch and the motor. It probably is not a resistor but an electronic module similar to a dimmer. May or may not be an easy fix but the motor should be fine on high speed.
zircon is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
