Hot Tub Wireing - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 12:29 AM   #1
Hot tub wireing
I have a hot tub that requires a 32 amp imput. The cable I have is Teck #10 / 30 amp .The wire will be exposed to the exterior of the house and the climate is approximate - 3 C to - 25 C for 5 month of the year when the hot tub will be running.Question is should I have a 40 amp breaker, I understand that the cable I have is rated for 33 amps.
kewen is offline   Reply With Quote
Old 09-21-2010, 03:11 AM   #2
" Euro " electrician
frenchelectrican's Avatar
You should upgrade that to 10mm˛ { # 8 AWG } Tek cable due the 32 amp load and you will need 40 amp breaker and you should have a RCD { GFCI } breaker on it unless the spa have it in there.
And just hang on one of the Canada guys will comfirm this one and I am pretty sure this is correct.
Merci.
Marc
wireing a new breaker to one room wolftickets Electrical 4 03-01-2010 01:23 AM
Small Ac Motor Wireing outback HVAC 13 11-06-2009 06:34 PM
noob wireing question shame302 Electrical 6 05-16-2008 09:33 PM
trailer wireing 1500 ram 79monztah Automotive Repairs 2 05-15-2008 11:49 PM
Wireing 3 diferent light into one box oxicottin Electrical 10 05-13-2008 08:47 PM
