Hot Tub Water Is Electrified With 60 Volts? Please Help - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 12:08 PM   #46
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
was any problem found other than that 3 vs. 4 wire feed or was the voltage problem basically attributable to the wire count?
Old 09-23-2010, 01:04 PM   #47
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by fiamen55 View Post
Well new box and wires installed.....FIXED THE PROBLEM See photos below of the new components. Thanks again for everyones input. Be safe
I am glad it work out good for ya that slove the issue now you can enjoying the spa again.
Speaking of SqD I never see the RCD breaker in HOM series in that fashion
That disconnect switch that is pretty common item I useally use them and that is a first time I ever see C-H disconnect switch use red handle on that.
but otherwise it look good did that electrician keep the netural and ground seperated at the disconnect switch ??
Merci.
Marc
Old 09-23-2010, 01:22 PM   #48
Nap...from what i understand from talking to them the original GFCI that I had was not working properly anyway, plus the wire count was wrong. they said the spa was never properly grounded as some have observed here in my previos photos.
French elec... Not sure what he inside of the box looks like. He did say he "bonded" a neutral and a "ground" I think?? I'll take the face plate off the box and post a pic of the wiring so you can see.
fiamen55 is offline   Reply With Quote
The Following User Says Thank You to fiamen55 For This Useful Post:
frenchelectrican (09-23-2010)
Old 09-23-2010, 01:27 PM   #49
Please do take a photo I want to make sure they done in correct way due you mention bonded that kinda give me willies I just don't like it until I see that photo to make sure it is legit.
Merci.
Marc
Old 09-23-2010, 02:14 PM   #50
Here ya go.... Plus I have the Square-D in the main box in the basement Im sure you know what that looks like but let me know if you want to see that too.
Old 09-23-2010, 07:43 PM   #51
That look allright I have no issue with that set up and I genrally don't use split bolt that often anymore I use the Polairs connector or large bleu wirenut both will work just fine.
Merci.
Marc
Old 09-23-2010, 09:33 PM   #52
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'd be curious if the voltage returns with the new equipment ground disconnected.
Maybe a potential difference existed due to the original missing equipment ground not bonding the spa panel to the service?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
