Hot Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By jeffmattero76
  • 1 Post By joed
Old 10-11-2016, 12:03 AM   #1
Rewards Points: 16
hot receptacle
here the scenario Source to 3 way to light to 3 way to receptacle (keeping the receptacle hot.
The part I can is the hot and neutral wires to the receptacle.
jamesdink is offline   Reply With Quote
Old 10-11-2016, 06:27 AM   #2
Rewards Points: 18
Re: hot receptacle
If you speak english, and in full sentences, someone here may be able to help you.
Sent from my LG-D415 using Tapatalk
SPS-1, MTN REMODEL LLC and Power- like this.
jeffmattero76 is offline   Reply With Quote
Old 10-11-2016, 07:58 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,968
Re: hot receptacle
You need four wire cable between the switches and the light.
Power- likes this.
The Following 2 Users Say Thank You to joed For This Useful Post:
jamesdink (10-13-2016), rjniles (10-11-2016)
Old 10-13-2016, 11:53 AM   #4
Rewards Points: 16
Re: hot receptacle
That's what makes the difference and because he made us look for the answer. didn't know that solve the rest of my projects.
Old 10-17-2016, 11:22 AM   #5
Rewards Points: 16
Re: hot receptacle
My teachers says that would a good solution if you had enough on a project to afford 12/4 BX cable. Local Home Depot has it at $500 for 250 ft. he said there is a way to connect with just 2 and 3 BX cable. I don't see it. he is not going to tell us till next month in class. Here are the things we have to do is attached. The ones I am having problems with Job 21-30
Old 10-17-2016, 01:58 PM   #6
Super Moderator
joed's Avatar
Re: hot receptacle
You could run two 2 wire cables, but there is no other code way to do it without four wires.
OK to convert this receptacle to GFCI receptacle? Rav Electrical 5 03-29-2016 04:01 PM
Added new receptacle to daisy chained outlets, failure upstream? Didymus21 Electrical 10 12-03-2014 09:38 PM
switch for middle of run receptacle jpau00 Electrical 4 02-05-2013 04:20 PM
Unusual Receptacle Wiring Avanzi Electrical 5 01-20-2013 08:20 AM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
