Hooking Up A Welder - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 01:14 AM   #16
Rewards Points: 150
Ok I tried again and the conductor screws do seem like they will hold the #14 wire, but the clamp will not. I'm not sure if it came with a spacer or not. It did come with a metal piece shaped sort of like a half circle...with that on there, tightened all the way, it still does not hold the wire securely. Do I need to buy an additional spacer or something?
Thanks!
Dave
dc4nomore is offline   Reply With Quote
Old 10-18-2009, 01:24 AM   #17
" Euro " electrician
frenchelectrican's Avatar
Dave .,
Try to invert the cable clamp I know some are designed to work both way so try it as long it don't " cut " the cord.
If you can run the plug model number I should able know what the answer to it and I know some did come with optional spacer kit however some peoples what they do is wrap a couple layers of electrical tape to increase the size to get the clamp hold down good.
Merci.
Marc
Old 10-18-2009, 01:42 AM   #18
Rewards Points: 150
Good idea Marc. Inverting the clamp or wrapping with electrical tape should do the trick.
The plug I have is the Leviton 931. Here is a link to it:
http://www.hardwareworld.com/3050a-2...g-pTVE3UV.aspx
hooking up welder help? dmank Electrical 1 12-29-2008 11:48 AM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 01:38 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
MIG welding amakarevic Tools 28 02-20-2008 08:56 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 01:11 AM
