Hooking Up New Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 08:05 PM   #1
Hooking up new stove
I just purchased a new freestanding range to replace my older slide-in. The older stove was hardwired. I have three wires coming out of my wall. They are black, white w/red dot which I believe means it is being used as a hot and a bare wire. The new range has four terminals under the cover on the back. Is there a way to hardwire this together? If not what do I need to do to hook it up properly? Thanks for your time.
By the way. The old stove had flexible conduit coming out of it with a red, black, white, and bare wire. They had two of the wires connected together.
Billy
billynjuls is offline   Reply With Quote
Old 01-30-2010, 09:32 PM   #2
Electrical Contractor
kbsparky's Avatar
You need a NEMA 10-50R 3-wire range outlet for that circuit. The neutral bonding jumper will have to be in place on the new appliance as well.
-KB
Old 01-30-2010, 10:44 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 29,550
Your stove instruction manual should have the info on how to connect it as a three wire setup.
What size cable and breaker was on the old range?
Hooking up a non-equipped pellet stove to a home thermostat bobbyc HVAC 4 09-25-2009 03:24 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 04:38 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
