Honeywell V4073 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 05:29 AM   #1
honeywell v4073
hi, i have trouble with my central heating, it will only warm the rads when the water is being heated, as soon as the water is hot the rads go off. my husband thinks its the honeywell mid postition valve, we think it may have been wired wrongly the grey and yellow wire look round the wrong way, but we are not sure, can anyone help, has anyone got a photo or diagram[/
mickthehat is offline   Reply With Quote
Old 10-23-2010, 06:02 AM   #2
Electrical Contractor
kbsparky's Avatar
It sounds like your aquastat is controlling your circulator pump. The thermostat should be controlling the circulator. It might be a simple matter of changing a control wiring connection to fix your problem.
You may want to post this question over in the HVAC section.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
mickthehat (10-23-2010)
Old 10-23-2010, 06:19 AM   #3
thanks for your quick reply x
Old 10-23-2010, 06:27 AM   #4
honeywell v4073
can anyone help. i am having trouble, my central heating rads will only get warm when my hot water is being heated, and as soon as the hot water is hot enough, the rads stop being heated, i think it might be a wiring problem, the guy who came and looked at it wasnt that good. if you can help me with either a diagram or photo. that would be a great help. i think the grey and yellow wires arent in the right order, any help will be greatful...
Old 10-23-2010, 11:39 AM   #5
An old Tradesmen
Rewards Points: 2,930
The zone valve should control the circ and or aquastat.
Post pics of your wiring.
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 09:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
