Homeline Main Breaker Interchange Ability - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 07:49 AM   #1
Homeline Main Breaker interchange ability
I have an overloaded 100 amp main breaker panel. To save time, I want to upgrade to 150 amp service wire and change the 100 amp main to a 150 amp. Will the new 150 amp main breaker fit the existing 100 amp homeline panel?
fred sanford is offline   Reply With Quote
Old 02-15-2012, 07:53 AM   #2
Julius793's Avatar
You cannot just do that!!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-15-2012, 08:28 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,666
Depends on the panel specs.
The panel will; tell you the max size of main breaker, and size of the buss.
I have replaced a 150 amp breakers to 200 amp in many homeline panels.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
fred sanford (02-15-2012)
Old 02-15-2012, 08:55 AM   #4
rrolleston's Avatar
Rewards Points: 1,014
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would have someone check out your service drop and meter socket. before the breaker panel before doing anything. They have to be able to handle the new load. I doubt they are because I don't see people doing anything like that Unless they just had some leftover cable and used larger.
Many of the murray panels that I have seen are 125 amps but only used for 100 or less. Same with some 150 amp palels have a sticker stating the max main breaker size 200 amp.
rrolleston is offline   Reply With Quote
Old 02-15-2012, 03:12 PM   #5
I appreciate your help. I know a 200 amp main breaker is larger than the 100 amp style. It's useful to know that the 150 and 200's are interchangable.
Thanks again
Old 02-15-2012, 04:35 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It varies around the country but the poco determines what service upgrades are needed and what they will provide. If you have 100 amp service now it may mean you will have to have a new drop run or maybe not you will have to find out what is going to be needed. Our poco jumps upgrades from 100 to 200 amps...there is no 150 amp upgrade. However there is nothing stopping you from installing a 150 amp panel on a 200 amp service.
If you have a currently installed panel and it's rating is 100 amps and you have a 100 amp main breaker installed that is the largest ocpd as a main that you can install. It will not accept a 150 amp main breaker.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 09:51 AM
Main 100 amp breaker Tony vargas Electrical 1 04-26-2011 08:05 PM
Heating question on main panel breaker, 15A viper Electrical 5 04-04-2011 07:31 AM
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 08:08 PM
Main Breaker panel question stagger19 Electrical 5 08-15-2006 03:57 PM
