Home Reno Wiring Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 04:44 PM   #16
Mad Scientist
I'd probably just wirenut all the hots together, all the neutrals together, and all the grounds together, with a short pigtail coming off of each to connect to the receptacle in that box.
McSteve is offline   Reply With Quote
Old 05-20-2010, 10:26 PM   #17
Send a message via ICQ to Henry H
McSteve, many thanks, it worked like a charm. Thanks again. Henry
Henry H is offline   Reply With Quote
Old 05-21-2010, 08:24 PM   #18
Originally Posted by Henry H View Post
McSteve, if you are still on here, I have a question for you. I have a circuit going to a receptacle. I want to branch off both directions from that receptacle to other receptacles in both directions. I now have 3 - 14/2 wires comming into the first receptacle box. The first wire is power from another source, the second will branch left from the #1 receptacle and the third will branch right from the #1 receptacle. What connection is required here? Thanks. Henry
If you don't mind, I can answer for McSteve.
One way would be to connect the wires from two cables with pig-tails. The pig-tails are connected to the receptacle. The third cable wires are connected to the receptacle also!
Adding additional wiring to new block home sailorman Electrical 6 05-28-2009 01:27 PM
Problem with wiring (really long post sorry) okacookie Electrical 10 04-21-2009 08:54 AM
Wiring Issue: Problem solving skkrman7482 Electrical 3 04-04-2009 06:32 AM
problem with wiring...celing fan/switch anywhofaq Electrical 8 05-09-2008 04:20 PM
Running new 2nd floor wiring on *exterior* of our home? drh Electrical 12 02-16-2008 06:27 PM
