Home Network - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 10:12 AM   #1
Home Network
Hi - long time lurker, first time poster.....
I have a Blu-ray dvd player and a Directv DVR which can both be connected to the internet using their ethernet ports. My computer is on the other side of the house, but I can pretty easily run Cat5 cable from the computer location to the entertainment center where the DVD & DVR players are. My question is - do I need to run two Cat5 cables, or can I use a wall plate that has 2 jacks and connect one cable to both jacks (in other words, can the DVD & DVR share the same cable)?
rundirt is offline   Reply With Quote
Old 02-26-2010, 11:28 AM   #2
Just call me Andrew
Rewards Points: 1,032
You can't "split" an ethernet cable like you are thinking. I assume the source for this cable will be your router?
If so, you can run 1 cable, and get a cheap 4-port switch that would "split" it for you. This switch is not wall-mountable and needs its own power. Something like this:
http://www.newegg.com/Product/Produc...82E16833127085
Other options are to use a wireless, of which I am not a fan, or to run two cables and connect both of them to your router, assuming you have two ports open.
Andrew
secutanudu is offline   Reply With Quote
Old 02-26-2010, 12:18 PM   #3
The source will be my modem which has 3 'Local Ethernet' ports available. Looks like I'll just pull two cables from the computer location to the entertainment location so the DVD player and DVR will each have a dedicated line to the modem.
Old 02-26-2010, 01:20 PM   #4
Just call me Andrew
Functionally, there's no difference between two-wires and one with a switch at the TV-end. Your 3 available "Local Ethernet" ports are likely a switch anyway, just one that happens to be located inside your cable modem.
Two wires will work, though.
Andrew
Old 02-26-2010, 01:52 PM   #5
Rewards Points: 596
If you're going to run one cable, running two at the same time is not significantly harder.
operagost is offline   Reply With Quote
Old 02-26-2010, 05:03 PM   #6
ojc
ojc's Avatar
Do you have two DTV boxes in the house?
They are coming out with the Multi Room Viewing (the beta is out and working....sorta) and I would suggest laying a cord for each device.
I would also lay CAT6 if you are complete nerd.
MRV
ojc
ojc is offline   Reply With Quote
Old 02-28-2010, 08:40 PM   #7
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 101
Just a thought...
It may be easier to move your modem/router to the media area and just use a wireless card for the computer.
ink is offline   Reply With Quote
Old 02-28-2010, 09:11 PM   #8
Just call me Andrew
Or move the modem/router to the media area and run just 1 wire back to your computer, if you don't want to do wireless.
Andrew
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Home Network Help Frank Networking 10 11-28-2008 02:59 PM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
Home Addition destepan Building & Construction 6 12-05-2007 12:28 PM
