Hole In Service Entry Wire - Electrical - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 4 Post By joed
  • 4 Post By brric
  • 1 Post By Domo
Old 02-19-2019, 05:34 PM   #1
Hole in Service Entry Wire
I accidentally drilled a hole in the service entry wire a few months ago. Other than the light briefly flickering when it initially happened but other than that I hadn’t caused any problems at all. I know I got extremely lucky! I got a quote from an electrons of 925$ to replace it but I’m wondering how badly it needs to be replaced since it hasn’t caused any problems?
Kbcundza is offline   Reply With Quote
Old 02-19-2019, 05:53 PM   #2
Guapo
Rewards Points: 11,950
Re: Hole in Service Entry Wire
By service entry wire, do you mean one of the service legs?
Guap0_ is offline   Reply With Quote
Old 02-19-2019, 06:03 PM   #3
Rewards Points: 58
It is hard to know for sure, but you may have severed one of the conductors reducing it's capacity. It could also short out in the future causing a potential fire. Glad you are ok,!
Wiredindallas is offline   Reply With Quote
Old 02-20-2019, 12:03 AM   #4
dmxtothemax's Avatar
Rewards Points: 7,378
Without at least seeing a picture of the damage or an accurate description
then we cannot say for sure.
Depending on the depth of the damage you can reduce the wires current carring capacity and also it's mechanical strength.
Also if water getts in then corossion is likely.
Most Electricians will be shuddering now !
dmxtothemax is offline   Reply With Quote
Old 02-20-2019, 01:08 AM   #5
Rewards Points: 836
You're very lucky. A man in a neighboring town was killed when he did that a couple years ago. He was drilling out through the sill from in the basement and drilled right into the conduit between the meter socket and the panel.
Personally, I'd almost guarantee that I couldn't sleep in the house with it like that.
iamrfixit is offline   Reply With Quote
Old 02-20-2019, 01:53 AM   #6
Mystriss's Avatar
Rewards Points: 3,100
I'd be worried about the insulation having been cut (that's the "jacket" of plastic like material) it's the part that stops the current from getting out of the metal wire (a bit of a laymen explanation)
I'd think it'd be a fire hazard...
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 02-20-2019, 07:04 AM   #7
Super Moderator
joed's Avatar
Rewards Points: 23,082
If the light flickered when it happened then you definitely damaged the insulation on at least two of the wires inside the cable. It should be replaced.
Old 02-20-2019, 09:19 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 530
Are you talking about about a cable (2 or more wires) or a single conductor.?
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 02-20-2019, 09:22 AM   #9
Master Electrician
Rewards Points: 4,982
This is one of the most ridiculous threads ever. Replace the conductors. Full stop.
jbfan, Msradell, jhil and 1 others like this.
brric is offline   Reply With Quote
Old 02-20-2019, 05:42 PM   #10
Contractor/Engineer
Rewards Points: 1,092
Yeah, and my girlfriend is just a "little bit" pregnant... maybe I should wait?
Perhaps the fire will burn out by itself...
Sorry - I don't mean to be disrespectful - OP has a problem and did ask, however, there is NO WAY to let that wire stay unrepaired.
Msradell likes this.
Domo is offline   Reply With Quote
Old 02-20-2019, 05:49 PM   #11
Mystriss's Avatar
Well I do think a couple layers of electrical tape can fix some nic situations, this just isn't one of those types of situations. Personally, I just replace all nic's if they're going to be difficult to access, like a Romex nic (in wall) I'd defiantly replace, but maybe a lamp cord nic I might tape up - depending on how often said lamp cord is moved, and how easily I can make sure the tapes still sticking (they stop sticking after a while.) I'd never tape up an extension cord though because you roll them up so often it'd lose the tape, etc. Situational...
WIFI thermostat? dommm HVAC 10 01-21-2019 04:28 PM
What SE Wire (new service) no_Wedge Electrical 28 08-24-2012 10:18 PM
Service entrance wire WillK Electrical 1 08-19-2011 09:57 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
