Hole Sealant - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2014, 11:44 AM   #1
Rewards Points: 190
Hole Sealant
What do you guys use to seal up holes from electric wires running from outside in or from the basement or crawlspace in - my friend used to use a substance that he referred to as "C-4" but I never knew what is was - its a putty like substance that hardens over time and keeps critters out.
Thanks in advance.
RumDiet is offline   Reply With Quote
Old 10-27-2014, 12:10 PM   #2
Rewards Points: 774
Thanks in advance.
That product is called duct seal. I use that or silicone caulk or fast setting masonry patch. Or combinations. Depend on the circumstance.
busman is offline   Reply With Quote
Old 10-27-2014, 12:57 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 92
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Installing Mammoth Basketball Goal - Size of Hole? keady27 Building & Construction 1 03-29-2011 09:07 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
