Is A Hi-power Electric Clothes Dryer Design Still Available? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 06-23-2019, 06:27 PM   #1
Rewards Points: 84
Is a hi-power electric clothes dryer design still available?
I inherited a Kenmore "Sears Best" clothes dryer. It is more than 30 years old and works well. I measured the current recently at 25A. The plate lists 28A, 6,000 Watts! The dryer has never tripped a breaker.
Were electric clothes dryers designed to produce hotter temperatures 30+ years ago?
Is this current load too high for 2x #10 w/G on a 30A DP breaker?
Thanks, RogerDog
RogerDoger is offline   Reply With Quote
Old 06-23-2019, 07:23 PM   #2
Rewards Points: 58
That is slightly more than the current dryers, but I would not be concerned of it being on a 30 amp circuit. As you stated, it is actually pulling only 25 amps. Your actual voltage is probably slghtly higher than the dryer nameplate stated resulting in lower amperage. When the voltage is higher, the amperage is lower while the wattage remains the same (watts divided by voltage equals amps).
Wiredindallas is offline   Reply With Quote
Old 06-23-2019, 08:58 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 29,240
Re: Is a hi-power electric clothes dryer design still available?
Clothes dryer standard circuits are 30 amp. With those numbers the breaker should not be tripping.
Unless your dryer runs non stop for 3 hours continuous, it is a non-continuous load.
Old 06-23-2019, 09:04 PM   #4
Rewards Points: 1,418
This is wrong for resistive elements including the dryer heating element.
The resistance is relatively fixed (varies a little based on temp), the current is determined by voltage and resistance.
Wattage is just a rating and varies in the real world as voltage changes.
Dryers can cycle the element to not overheat.
Most are 5000w when the element is on.
Its the least efficient appliance in the home.
mpoulton likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
mpoulton (06-23-2019)
Old 06-23-2019, 09:30 PM   #5
Rewards Points: 16
It will be nice when the ultrasonic dryers hit the market.
Sent from my SM-G960U using Tapatalk
spitz1234 is online now   Reply With Quote
Old 06-23-2019, 09:47 PM   #6
^There are heatpump dryers out there.
I just use a indoor rack, no wasted energy.
Old 06-24-2019, 08:01 PM   #7
wNCmountainCabin
NCmountainCabin's Avatar
Rewards Points: 202
is that reading for a double-pole 30amp 240v Dryer plug and breaker?
NCmountainCabin is offline   Reply With Quote
