Help Wiring Light Switch W/ 4 Wires - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2019, 08:09 AM   #16
Rewards Points: 118
Re: Help Wiring Light Switch w/ 4 Wires
Originally Posted by hkstroud View Post
Some where you have two 3-way switches that control the light that the 4-way switch controls. Turn breaker off. Temporarily connect red to red and black to black. Turn breaker back on and see it the 3-way switches, the ones that work with the 4-way switch, not the ones in this box, work properly.
If the 3-way switches work properly, connect the black and red of one cable to one side of the 4-way switch and connect the black and red of the other cable to the other side of the 4-way switch. It doesn't matter which wire goes where as long as the black and red of one cable is connected to one side of the switch and the black and red of the other cable are attached to the other side of the 4-way switch.
OK -- So I cleaned up the wires a bit -- shortened all the slack etc.
In THIS switch box:
The Breaker to the 2 [unrelated] 3-way switches on the left is currently OFF and the switches themselves are "off"
The 4-way switch -- I connected the 2 reds and the 2 blacks like you said -- put that breaker back on - and the light works. I located the other switch that turns this same light on/off and it works fine.
All the other lights on the same circuit are working AOK
Now - I am just a little confused about the next part -- because like I mentioned - I mixed up which red/black PAIR was on the LEFT and which red/black PAIR was on the RIGHT
Are you saying it doesn't matter which red/black combo goes to left and which combo goes on right ?
Or do I need to determine what the original pairing of each is first?
If so... how do I do that? [i think you explained this already - but I want to be sure]
nysepete is offline   Reply With Quote
Old 02-24-2019, 08:32 AM   #17
hkstroud's Avatar
Rewards Points: 6,684
That is correct. It doesn't matter which wire goes where as long as one pair of black and red wires (the black and red wire from one cable) goes on one side of the switch and the other pair (a black and red wire from the other cable) goes on the other side.
The black from one cable can go to the top terminal and the red of that cable to the bottom terminal or the red can go to the top terminal and the black to the bottom terminal.
Same thing for the other cable (what you are calling a pair). The two pairs do not have to match. The black from one cable can go to the top terminal on one side and the red of the other cable can go to the top terminal on the other side.
Only thing that matters is that the two wires of a cable (a pair) go to the same side of the switch.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
nysepete (02-24-2019)
Old 02-24-2019, 01:51 PM   #18
Rewards Points: 118
YOU my friend. Have solved my problem and made me smile. You have let there be light!
Isn't there a way to give you an up vote or something????
Thank you from the bottom of my heart.
Old 02-24-2019, 02:28 PM   #19
hkstroud's Avatar
Isn't there a way
Yes. Go do something that you really like. Something that later in life you will look back at and say "Boy, I'm glad I did that".
Harold,
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 22 09-28-2019 09:54 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
Electrical wiring/ switch wiring - mixed wires tien009 Electrical 1 07-21-2012 10:53 PM
Ceiling Fan with light wiring? Snowwolf Electrical 7 06-28-2010 08:30 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
